Hi All,
I've been looking for a basic routine to help me run a string of commands on all blocks within an open drawing.
I'd like to be able to run 'convert to mesh' type commands, and I know from previous limited experience, they can be problematic in certain code formats - vls-command maybe?
Most of the 'block batch' posts I've seen here so far are only concern with putting geometry on specific layers etc.
I suppose in its most basic form could I run a macro on all blocks within a drawing?
Any help would be much appreciated,
Thanks
Jody
You need to explain way more what your trying to do and how complex the changes are to which blocks, may need a number of conditions being met to carry out certain commands.
  • 1 month later...
Hi BIGAL
Thanks for your quick response  - apologies for my late reply - I started looking into what I wanted in more detail, and it turned into a bit of a rabbit hole!
I'll park this for the time being.
Thanks
