Ellen Finkelstein's Blog Posted August 24, 2020 Share Posted August 24, 2020 Sometimes people have trouble displaying a toolbar that isn’t visible, or a toolbar seems to disappear for no apparent reason. Here are some tips for displaying toolbars. 1st method The easiest way to display a toolbar is to right-click any visible toolbar. This displays the list of all your toolbars, as you see here on the right. Just pick the one you want to make it visible. However, certain custom toolbars, and the Express Toolbars aren’t listed. To find them, right-click any blank (gray) area next to a toolbar. Click ACAD to find the same toolbars you’d get by right-clicking a displayed toolbar. Tips: If all your menu has disappeared, quickest thing to try out first is to use MENULOAD command to reload the menu. Also make sure to Choose Classic as the workspace 2nd method If you know the name of the toolbar, another option is to use the command line form of the TOOLBAR command, by typing -toolbar. At the resulting prompt, enter the name of the toolbar. Then, at the Enter an option: prompt, press Enter to show the default option, which is Show. Here’s what it looks like: Command: -toolbar Enter toolbar name or [ALL]: dimension Enter an option [Show/Hide/Left/Right/Top/Bottom/Float] <Show>: ## Dynamic block is another great productivity tip to master. Sign up below to get your Free tutorial on creating a complete dynamic block, including a drawing to practice on. You’ll make a movable chair, resizable desk, and more. 3rd method An alternative is to choose View> Toolbars. Starting with AutoCAD 2006, this opens the Customize User Interface (CUI) dialog box. As you can see, the On By Default value is Hide. Click to reveal a drop-down arrow, and choose Show to display that toolbar by default. 4th method An excellent way to control the display of toolbars is with workspaces. You can create a workspace that displays any set of menus, toolbars, and palettes (called dockable windows in the CUI dialog box). You can do this in 2 ways. Display the toolbars that you want. In the Workspaces toolbar, choose Save Current As from the drop-down list. Enter a name and choose Save. Now, you can choose that workspace any time you want it from the Workspace toolbar (assuming you can find the Workspace toolbar!). You can also create a workspace in the CUI dialog box. Right-click the Workspaces node and choose New> Workspace. Then type the name of the workspace. Click the Customize Workspace button. What this does is add a checkbox next to all the items on the left. Then you check what you want and uncheck what you don’t want. For each item, you can specify its properties, such as Docked or Floating. Finally, click Done. Finding lost toolbars Toolbars can sometimes get “lost” due to a change in screen resolution. If you recently changed the resolution of your screen, try a higher resolution, which will show more items at the edge. You can protect toolbars from moving by locking their position. Right-click any toolbar and choose Lock Location. Then choose Floating Toolbars to lock those that aren’t docked, Docked Toolbars, or All. Do you want more productivity tips to help you Draw and Edit faster and easier? Check out “Top Productivity Tips Every AutoCAD User Should Know” The post Display lost toolbars in AutoCAD appeared first on AutoCAD Tips Blog. View the full article Quote Link to comment Share on other sites More sharing options...
