Call "pType" dialog over an active/loaded DCL window
Hi BigAl ,
 Please , can you attach some samples?
Regards ,
Costin
  • Replies 22
  • Costinbos77
    10
  • BIGAL
    5
  • eldon
    4
  • Jonathan Handojo
    2
Posted Images
This is cut from other code so hope makes sense uses slide library ctone.slb
(setq ai_pts_lst '("ctone(tlsw)" "ctone(studd)" "ctone(trsw)"
                   "ctone(studr)" "ca3blank" "ctone(studl)"
                   "ctone(blsw)" "ctone(studu)" "ctone(brsw)")
(setq ai_pts_lst2 '("33sq1" "33sq2" "33sq3" "33sq4" "33sq5" "33sq6""33sq7" "33sq8" "33sq9" ))
(defun sq_pick ()
  (cond
    ((= ans "33sq1")(setq ang1 1.5708)(setq ang2 3.1417)(tl))
    ((= ans "33sq2")(tm))
    ((= ans "33sq3")(setq ang1 1.5708)(setq ang2 0.0)(tl))
    ((= ans "33sq4")(tm))
    ((= ans "33sq5")(princ "run other clean up"))
    ((= ans "33sq6")(tm))
    ((= ans "33sq7")(setq ang1 3.1417)(setq ang2 4.7125)(tl))
    ((= ans "33sq8")(tm))
    ((= ans "33sq9")(setq ang1 4.7125)(setq ang2 0.0)(tl))
; calculates next slide
(defun alan4 ()
(setq x (+ x 1))
(setq sldname (nth x ai_pts_lst))
; third step
; set up slide libraray
(defun ai_ptype_start ()
  (setq x -1)
  (foreach pts0 ai_pts_lst2
      (alan4)
      (start_image pts0)
      (slide_image 0 0 (- (dimx_tile pts0) 1) (- (dimy_tile pts0) 1) sldname)
      (end_image)
; this is second step
(defun ai_ptype_main (/ globals)
  (ai_ptype_start)
;now check each sq if picked then run alan2
  (foreach pd0 ai_pts_lst2
    (action_tile  pd0  "(done_dialog)(setq ans $key)")
  (start_dialog)
; this is first step
  (if (= w2 nil)(setw2))
  (setq app "dd3x3.dcl")
  (if (= id_3x3 nil)
    (setq dcl_id (load_dialog app))
    (setq id_3x3 dcl_id)
  (if (not (new_dialog "dd3x3" id_3x3))
  (exit)
  (ai_ptype_main)
  (sq_pick)
//  DD3x3 dialogue.  Used by the DD3x3 command in DD3x3.lsp.
//  Called from the AutoCAD Release 12 Standard Menu.
dd3x3 : dialog {
  label        = "Please choose item";
  : column {
    : row {
      : image_button {
        key          = "33sq1";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
        allow_accept = true;
      : image_button {
        key          = "33sq2";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
      : image_button {
        key          = "33sq3";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
    : row {
      : image_button {
        key          = "33sq4";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
      : image_button {
        key          = "33sq5";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
      : image_button {
        key          = "33sq6";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
      : row {
      : image_button {
        key          = "33sq7";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
      : image_button {
        key          = "33sq8";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
      : image_button {
        key          = "33sq9";
        width        = 10;
        aspect_ratio = 1.0;
        color        = 0;
ok_cancel;
Thank you very much BigAl,  for your support !
Regards ,
Costin
