Bill Tillman Posted September 16, 2020 Posted September 16, 2020 I'm working with AC 2021 and preparing a 3D rendering. I recall that there was a setting for the sky, with illumination, etc... but I can't seem to find where to set that. I set PERSPECTIVE to 1 and then opened up the skyproperties window. But all it shows is a time and date for the view. Sunproperties gives me no help either. Been so long since I worked with rendering so any advice would be appreciated. Quote
Cad64 Posted September 16, 2020 Posted September 16, 2020 Make sure your LIGHTINGUNITS variable is set to 1 or 2. This will give you a lot more options in the Sun Properties palette. Also make sure SUNSTATUS and SKYSTATUS are both set to 1. Quote
Bill Tillman Posted September 17, 2020 Author Posted September 17, 2020 Thanks. They certainly changed a lot of the settings in the last few releases from AutoDesk. Quote
Cad64 Posted September 17, 2020 Posted September 17, 2020 1 hour ago, Bill Tillman said: Thanks. They certainly changed a lot of the settings in the last few releases from AutoDesk. I'm still using 2018, but yeah, it's a lot different than it used to be. It seems like they keep taking options away and leaving us with the bare minimum. I like having more control which is why I use other programs for 3D work. Quote
