PDFAttach at a particular location and scale
I am trying to figure out how to attach a pdf to a certain location and scale. I thought I could browse for the file then tell it what to do from the command line.
(defun c:PDFXA (/)
  (initdia)
  (command "_.-PDFAttach")
  (if (> (getvar "CMDACTIVE") 0)
      (command "_None" '(1.75 0.4506 0.0))
      (while (> (getvar "CMDACTIVE") 0) (command ""))))
Thanks for any pointers!
Hi,
Something like this ?
(defun c:Test (/ pdf ins scl)
  ;; Tharwat - 24.Sep.2020	;;
  (and (or (setq pdf (findfile "C:/Users/Tharwat/Desktop/Test.pdf")) ;; Replace this path with your desired PDF full path of file.
           (alert "Opps, File not found <!>")
       (setq ins (getpoint "\nSpecify PDF insertion point : "))
       (or (initget 6)
           (setq scl (getdist "\nSpecify Scale of PDF file : "))
       (command "_.-PDFATTACH" pdf "1" "_none" ins scl "0")
Awesome! Hopefully this makes sense. I am putting together a lisp as a script using (command “do this”). Is it possible to browse for the pdf and then hard code the scale and location?
again. Thank you!
Do a bit more googling there is insert multi page pdf also.
Look into Getfile and Findfile options about where to start looking for pdf.
again. Thank you!
Certainly.
Give the following a shot.
  (and (setq pdf (getfiled "Select PDF file to attach" (getvar 'DWGPREFIX) "pdf" 16))
       (or (initget 6)
Thank you for this. My Question is, (And I could be thinking about this backwards), to create it in some form like the below?
(defun Test (/ pdf ins scl)
       (or (initget 6)
(defun C:PDFinsTest ()
(command "_zoom" "_extents")
(command "_rectangle" "0,0" "36,24")
(TEST pdf "1,1" "0.60")
(princ))
My pleasure. :)
This way?
(defun c:PDFinsTest (/ pdf)
                           (getvar 'DWGPREFIX)
                           "pdf"
                           16
       (command "_.-PDFATTACH" pdf "1" "_none" '(1.0 1.0 0.0) 0.6 "0")
Thank you Thank you, so much! That is what I was looking for. I think I can edit this easily now;).
