Filter Count Block Name(s) to an mtext
rcb007
I have blocks (9Stall, 10Stall, ADAStall)  and the same blocks that are nested in dynamic blocks (using arrays). Instead of bursting or exploding all the dynamic blocks. Is their a method to count those block names and provide a count that can be inserted into an mtext?
9Stall          191
10Stall        309
ADAStall     10
I looked into Lees Nested Block Counter, but it does not insert the count into the drawing and does not consolidate (total) the same name block totals.
 Block Count
 Primary Blocks (112)                                           Count
 ADAStall...........................................................2
 9Stall............................................................23
 10Stall...........................................................56
 10Stall Wide Dyn..................................................12
 9Stall Wide Dyn...................................................19
 Nested Blocks (429)                                            Count
 9Stall...........................................................168
 10Stall..........................................................253
 ADAStall...........................................................8
Edited by rcb007
