ktbjx
layer name as elevation is it possible?
ktbjx
hello, is it possible to have a routine that gets the layername as elevation??
i have this LINEs (plenty of them)
but they are all on different startZ and endZ and their layernames are just numbers, no strings
is it possible to have a routine to get the layernames and use it as startZ and endZ of my lines?
Share this post
Link to post
Tharwat
Hi,
That's sounds fun to write. :)
You are talking about LINE type objects and not polylines. Right ?
Share this post
Link to post
ktbjx
8 minutes ago, Tharwat said:
Hi,
yes sir, its LINE not polyline
Share this post
Link to post
Tharwat
Alright,
Try this quickie one.
(defun c:lay2elev (/ sel int ent get pos)
  ;; Tharwat - 13.10.2020	;;
  ;; Layer name to Elevation.	;;
  (and (setq int -1 sel (ssget '((0 . "LINE"))))
    (while (setq int (1+ int) ent (ssname sel int))
      (and
        (numberp (setq pos (distof (cdr (assoc 8 (setq get (entget ent)))))))
        (entmod
          (append get (list (cons 10 (append (mapcar '+ '(0. 0.) (cdr (assoc 10 get))) (list pos)))
                            (cons 11 (append (mapcar '+ '(0. 0.) (cdr (assoc 11 get))) (list pos)))
Share this post
Link to post
ktbjx
7 minutes ago, Tharwat said:
Alright,
      (and
        (entmod
it works! wow thank you so much!
this cuts my load!
Share this post
Link to post
Tharwat
Good for you.
Share this post
Link to post
