Shablab Posted October 13, 2020 Share Posted October 13, 2020 Hey guys, I have a HDD bore I'm working on getting a rough sketch into autocad. I have over 60+ rods on some of the drills. I am wondering if there is anything that asks for typical rod length and then I can import either a .txt or excel file to get rod angles from? The lisp I am looking for would, in this case, put polylines 15 feet long, back to back, at the respective pitches (-31%, -31%, -29%) which I converted into angles in degrees. Let me know how I can go about this or if anyone wants more information. Thank you. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 13, 2020 Share Posted October 13, 2020 Here is a simple example: (defun c:foo (/ d l p) ;; RJP » 2020-10-13 ;; Depths (setq l '(0. 3. 7.5 12. 15.5 23 33 43 100)) ;; Rod distance (setq d 15.) ;; Start point (setq p (list 0. 0. (car l))) ;; Make lines (foreach x (cdr l) (entmakex (list '(0 . "LINE") '(8 . "RODS") (cons 10 p) ;; Set point + distance and at Z value in list (cons 11 (setq p (list (+ d (car p)) (cadr p) x))) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
dspok Posted February 24, 2022 Share Posted February 24, 2022 Just curious. i work in plan view and maybe its a european problem. but how can i change it to draw horizontally and vertically downwards in plan view. thankyou Quote Link to comment Share on other sites More sharing options...
huygens Posted February 24, 2022 Share Posted February 24, 2022 how can this be made to work in planview? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 24, 2022 Share Posted February 24, 2022 (edited) Dspok so you want a 3d pline it would need maybe X & Y pitch then could draw vertically. line 0,0,0 0,2,10 3,3,20 0,0,40 -vpoint 1,1,1 Shalab post excel or txt and a dwg please. Edited February 24, 2022 by BIGAL Quote Link to comment Share on other sites More sharing options...
huygens Posted February 27, 2022 Share Posted February 27, 2022 thank you Bigal. I wasnt uptodate with this thread. Email problems. anyway. Ronjonp had a good lisp. And your hints are good. thankyou BIGAL. <- years active here Quote Link to comment Share on other sites More sharing options...
