zionshea Posted October 13, 2020 Share Posted October 13, 2020 When i copy paste from model space to layout i need to reduce size of objects by 1 to 10. I must use different dimstyles for same object once it is displayed on a vp. Of course this happens once i add dimensions while in layout space. When i use the command CHSPACE, objects are moved with proper size. Of course printing must be considered. How can i force same size of objects when cut paste from model to layout space and vice versa? Quote Link to comment Share on other sites More sharing options...
steven-g Posted October 14, 2020 Share Posted October 14, 2020 WHY??? why can't you leave everything drawn full size in modelsapce and use a viewport to view the objects in a layout using the viewport scale, this is how 99.9% (OK 99.9% is made up ) of users do it and is the recomended method. The reason you are having a hard time making this work is it is not meant to be done this way. Yes CHSPACE is designed this way. 1 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 14, 2020 Share Posted October 14, 2020 Yep, CHSPACE is a great command, take advantage of it. Quote Link to comment Share on other sites More sharing options...
zionshea Posted October 14, 2020 Author Share Posted October 14, 2020 There are many reasons for my question. For example I need to keep two sets of dimstyles for each scale. one for layout and one for model space. also when I use "Export layout to model" I need to enlarge the result 10:1. also as I said when I copy from model to layout I need to resize (reduce) by 1:10. (e.g. - I copy elevations and sections from model to layout) Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 14, 2020 Share Posted October 14, 2020 Do you not use a Viewport in Paperspace? Quote Link to comment Share on other sites More sharing options...
