thanhan1983 Posted February 5, 2009 Posted February 5, 2009 Hi every body, I'm have a small difficulty about Aligned Dimention. That is when i click on any Aligned Dimention and stretch one base point to new place, immediately the direction of dim line is also rotated. I don't know how to fix this dim line on only one direction. If any one have good way to solve this problem, please help me... Thanks in advanced!:wink: Quote
PS_Port Posted February 5, 2009 Posted February 5, 2009 Editing an aligned dimension by grips, can be tricky, as the grip point has to be stretch in the original direction of the aligned dim. I work aroud this by changing the UCS to the match the objects alignment, then the dimension can be stretch with ortho on. Command: UCS Current ucs name: *NO NAME* Enter an option [New/Move/orthoGraphic/Prev/Restore/Save/Del/Apply/?/World] : OB Select object to align UCS: Quote
thanhan1983 Posted February 5, 2009 Author Posted February 5, 2009 Oh, thanks alot PS_Port. I understand your decision, that is also a good solution. I will apply, but if any one have another way, feel free to share it. Quote
DECHAL Posted February 5, 2009 Posted February 5, 2009 Yes, I do the same but type UCS then E and select a line at the same angle as the dimension. UCS will jump to that angle. easy as! DECHAL Quote
