andra Posted November 1, 2020 Posted November 1, 2020 Hi. I'm new to autocad....if I have a drawing in 1:500000 how to convert it to 1:100 ? Thank you! Quote
masterfal Posted November 2, 2020 Posted November 2, 2020 select all, scale up 5000 (i think..) Quote
BIGAL Posted November 2, 2020 Posted November 2, 2020 Your dwg should be true size in model space if it has been scaled for some reason 100/500000 is the scale to use. Quote
RobDraw Posted November 2, 2020 Posted November 2, 2020 If this is indeed a proper drawing to start with objects drawn 1:1, you would be talking about paper space and the viewport is set to 1:500000. When you change the scale of the viewport, the objects are going get a lot bigger on paper but not in model space. Quote
