MR MAN Posted February 5, 2009 Posted February 5, 2009 I Have View Ports In Model Tab And I Need Use Command Pspace As In Layout Tab But It Doesn't Work Because I'm In Model Tab So How Can I Exit From This Viewports? Quote
JBullseye74 Posted February 5, 2009 Posted February 5, 2009 You click on one of your paperspace tabs - you only use PS when your in paperspace viewing your model through a viewport. Cheers :wink: Quote
MR MAN Posted February 5, 2009 Author Posted February 5, 2009 i mean i make active model configuration in model tab it take whole screen area so i need to exit from viewports to model space? as we use pspace in layout tab to exit from model to layout. thanks Quote
lpseifert Posted February 5, 2009 Posted February 5, 2009 If you're in the model tab, you're in model space, no options. If you don't want any viewports in model space... Viewports > Single. If you want to toggle between model tab and paperspace... Tilemode. Quote
MR MAN Posted February 5, 2009 Author Posted February 5, 2009 YOU DON'T UNDERSTAND ME lpseifert I ALREADY MAKE VIEWPORTS IN MODEL TAB BUT NOW I NEED GET OUT FROM VIEW PORT AREA TO ANY OTHER AREA IN MODEL TAB YOU CAN TRY MAKE active model configuration IN MODEL WITH 3 VIEWPORTS FOR EXAMPLE AND THEN YOU WILL UNDERSTAND WHAT I MEAN. THANKS Quote
JBullseye74 Posted February 5, 2009 Posted February 5, 2009 You can't make Viewports in Model Space!! http://www.autocadcentral.com/Tutorials/Lesson%2010/lesson10.htm Do some reading i found this quickly googled Paperspace & Viewports. Oh and chill with the Caps Quote
Tiger Posted February 5, 2009 Posted February 5, 2009 YOU DON'T UNDERSTAND ME lpseifert I ALREADY MAKE VIEWPORTS IN MODEL TAB BUT NOW I NEED GET OUT FROM VIEW PORT AREA TO ANY OTHER AREA IN MODEL TAB YOU CAN TRY MAKE active model configuration IN MODEL WITH 3 VIEWPORTS FOR EXAMPLE AND THEN YOU WILL UNDERSTAND WHAT I MEAN. THANKS Don't you just click or double-click to switch between the Model Space Viewports? The same you do when switching between Viewports in Layout mode. Quote
JBullseye74 Posted February 5, 2009 Posted February 5, 2009 Don't you just click or double-click to switch between the Model Space Viewports? The same you do when switching between Viewports in Layout mode. YEs but i just think he is confused and has made viewports in Modelspace which he wants to have created in Paperspace you get me? Quote
wannabe Posted February 5, 2009 Posted February 5, 2009 You can't make Viewports in Model Space!! http://www.autocadcentral.com/Tutorials/Lesson%2010/lesson10.htm Do some reading i found this quickly googled Paperspace & Viewports. Oh and chill with the Caps It is possible to have multiple viewports in model space. Try View --> viewports --> select the number of views you want. Quote
wannabe Posted February 5, 2009 Posted February 5, 2009 Your last post is indicative, but I had already replied. Quote
Tiger Posted February 5, 2009 Posted February 5, 2009 YEs but i just think he is confused and has made viewports in Modelspace which he wants to have created in Paperspace you get me? I know J :wink: Quote
rkent Posted February 5, 2009 Posted February 5, 2009 I Have View Ports In Model Tab And I Need Use Command Pspace As In Layout Tab But It Doesn't Work Because I'm In Model Tab So How Can I Exit From This Viewports? Type PS, enter. Or PAPERSPACE, enter. If the tab at the bottom of the screen don't show for PAPER or MODEL right click down there and check Paper/Model space to show. Now just pick the button MODEL or PAPER to get back. Also, start locking your viewports so you don't have this problem next time. Click on the viewport and right click or go to properties and lock. Quote
