happyunited Posted July 18, 2007 Share Posted July 18, 2007 I have a block that contains loads of blocks inside of it so its blocks within a block. when i try to explode it some blocks remain and then loads of lines display all over the place what is this? i have tried to upload it but it keeps failing Quote Link to comment Share on other sites More sharing options...
Strix Posted July 18, 2007 Share Posted July 18, 2007 can you do a screen shot then and show us the jpg? Quote Link to comment Share on other sites More sharing options...
happyunited Posted July 18, 2007 Author Share Posted July 18, 2007 here is a dwf hope it makes sense the circle is what it looks like then when i move it to the side and explode you see the result!!! blocks-Model.dwf Quote Link to comment Share on other sites More sharing options...
Strix Posted July 18, 2007 Share Posted July 18, 2007 bother - I'm cadless here, so I can't see it I probably wouldn't know the answer anyway :wink: Quote Link to comment Share on other sites More sharing options...
happyunited Posted July 18, 2007 Author Share Posted July 18, 2007 you only need dwf viewer Quote Link to comment Share on other sites More sharing options...
chulse Posted July 18, 2007 Share Posted July 18, 2007 can you look at it in the block editor to see what's happening? Quote Link to comment Share on other sites More sharing options...
ascen707 Posted July 18, 2007 Share Posted July 18, 2007 that happends dometimes to me too. So what I do is use the BURST command it will explode the block and it will let it keep what ever attributes it has just explode it before the other line come up. when you explode a block it brings everything that the attribute it has. Quote Link to comment Share on other sites More sharing options...
pjb84 Posted July 18, 2007 Share Posted July 18, 2007 Can you upload this in .dwg format? Quote Link to comment Share on other sites More sharing options...
PS_Port Posted July 18, 2007 Share Posted July 18, 2007 Looks like a dimstyle fubar, I would try DIM then UPDATE (select everthing) Cheers Paul Quote Link to comment Share on other sites More sharing options...
NoelStalker Posted October 29, 2008 Share Posted October 29, 2008 At the last place I worked, the burst command allowed me to explode a block without losing the information in the attributed text. I typed burst at this place and this is what I got "BURST Unknown command "BURST". Press F1 for help." Do you know is there a lisp file I can download and install to make burst work? Quote Link to comment Share on other sites More sharing options...
mugshot Posted October 30, 2008 Share Posted October 30, 2008 why dont u explode the things inside a certain block? block editor, right click the certain object left click and look for the edit block in place. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted October 30, 2008 Share Posted October 30, 2008 its unknown command cose its a command in Express menu that mean you did not install Express menu Quote Link to comment Share on other sites More sharing options...
neekcotrack Posted October 30, 2008 Share Posted October 30, 2008 its unknown command cose its a command in Express menuthat mean you did not install Express menu He's right it is a express command. Here is the same lisp you will find with express command. burst.lsp Quote Link to comment Share on other sites More sharing options...
JONTHEPOPE Posted January 6, 2009 Share Posted January 6, 2009 How DO I GET BURST to work in 07 is it possible ? do i need express tools? Quote Link to comment Share on other sites More sharing options...
mugshot Posted January 7, 2009 Share Posted January 7, 2009 How DO I GET BURST to work in 07 is it possible ? do i need express tools? just copy the lisp and appload on your cad... Quote Link to comment Share on other sites More sharing options...
JONTHEPOPE Posted January 23, 2009 Share Posted January 23, 2009 I just did a drag and drop + it didn't work so i installed express tools and what do you know burst works . i wonder why express isnt on standard install ?? Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted January 24, 2009 Share Posted January 24, 2009 it normally is, i find that if I.T. does the install, the do not know what is it so they untick it, or some time an error can occur during upgrade, where it is installed but not loaded, "Appload" ftw Quote Link to comment Share on other sites More sharing options...
