gsc
How to check if (vla-boolean A acIntersection B) is True or Nil?
gsc
Hi,
I have a sub function which executes a (vla-boolean A acIntersection B) command for 2 Regions.
I only want to check with this function if the 2 Region are intersecting or not (something like T or Nil)
And delete the regions afterwards (or can that be done by only checking?)
How do I do that?
(defun reg_intersect ( ss / reg_lst ent )
    (setq num 0)
    (repeat (sslength ss)
        (setq ent (ssname ss num))
        (if (= (cdr (assoc 0 (entget ent))) "REGION")
                (setq reg_lst (cons (vlax-ename->vla-object ent) reg_lst))
        (setq num (1+ num))
    (vla-boolean (car reg_lst) acIntersection (cadr reg_lst))
;;Note: there are always 2 Regions in my selection set
Share this post
Link to post
marko_ribar
All that crosses my mind is that you can check area of resulting region after boolean... If area of resulting region is smaller or equal than smaller (by area) reference region before boolean, then it's T otherwise it's nil...
Edited by marko_ribar
Share this post
Link to post
Roy_043
You might try using vla-intersectwith.
Share this post
Link to post
marko_ribar
Although I think that this metod is available and for REGION entities, in my experience I think that it's not properly implemented for REGIONS... Still I may be misteking, further checking is needed... In BricsCAD I don't quite know for this, you may be right Roy...
Share this post
Link to post
Tharwat
Maybe the fastest way is to check for the last entity before invoking the method then check after all if the same entity still the same or changed.
Share this post
Link to post
Lee Mac
Perhaps something like this?
(defun reginter-p ( rg1 rg2 / rtn tr1 tr2 )
    (setq tr1 (vla-copy rg1)
          tr2 (vla-copy rg2)
    (vla-boolean tr1 acunion tr2)
    (setq rtn (< (vla-get-area tr1) (+ (vla-get-area rg1) (vla-get-area rg2))))
    (vla-delete tr1)
    rtn
Share this post
Link to post
