Update attribute with actual $FILENAME$ lisp
Lee, if I were to not use the variable that is in Autocad itself, but wanted to replace the value for attribute DRAWINGNAME with only the text "UPDATED" - how would you modify the routine that you've just written? If I have this routine, it will help me update any blocks with either the a system variable or a regular text.
No hurry, as I think it's close to midnight maybe in England? As always, thank you.
  • Replies 23
  • Lee Mac
    11
  • kam1967
    8
  • uddfl
    3
  • dbroada
    1
Popular Days
Thanks, Lee. I tested your routine and I got an extra right parenthesis error. I took away the other two on the right and it works fine now.
(entmod (subst (cons 1 dNme)(assoc 1 aEntLst) aEntLst)))
(entupd e)
(setq aEnt (entnext aEnt)))))
(princ "\n No Title Blocks Found "))
;(command "_regenall")
(princ))
Well, this has been most educational. Thanks for the input, everyone! Have a wonderful day, okay? Grab some zZzZ too! :)
Hmm... I checked the updated routine that I posted and parenthesis number seems correct :huh:
You're welcome to test it, Lee. I know, it's tough being a perfectionist, isn't it? ;)
Again, untested:
(defun c:dwgupd (/ ss ans eLst dNme aEnt aEntLst)
 (vl-load-com)
 (if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 "TITLE") (cons 66 1)
    (if (getvar "CTAB")
      (cons 410 (getvar "CTAB"))
      (cons 67 (- 1 (getvar "TILEMODE")))))))
     (if (not oans) (setq oans "Filename"))
     (initget "Filename Updated")
     (setq ans (getkword (strcat "\nFilename or Updated? {F/U} <" oans ">: ")))
     (if (eq "" ans) (setq ans oans) (setq oans ans))
     (if (eq ans "Filename") (setq dNme (vl-filename-base (getvar "DWGNAME")))
   (setq dNme "UPDATED"))
   (setq eLst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
   (foreach e eLst
     (setq aEnt (entnext e))
     (while (not (eq "SEQEND" (cdadr (setq aEntLst (entget aEnt)))))
   (if (= "DRAWINGNAME" (cdr (assoc 2 aEntLst)))
   (princ "\n<!> No Title Blocks Found <!> "))
 (princ))
Off to bed now to catch some Zzzzs :star:
