brianfengming Posted December 3, 2020 Posted December 3, 2020 (edited) i intend to change the element color in specific layer. i find the lisp as follows. the lisp will change all objects color. is it possible to modify it to meet our requirement. ===QUO== ;Changes the colour of ;all objects in drawing ;icluding blocks and references ;;IT WILL CHANGE ALL REF ALSO MAKE BACKUP OF ALL REF BEFORE USING (defun mip:layer-status-restore () (foreach item *MIP_LAYER_LST* (if (not (vlax-erased-p (car item))) (vl-catch-all-apply '(lambda () (vla-put-lock (car item) (cdr (assoc "lock" (cdr item)))) (vla-put-freeze (car item) (cdr (assoc "freeze" (cdr item)))) ) ;_ end of lambda ) ;_ end of vl-catch-all-apply ) ;_ end of if ) ;_ end of foreach (setq *MIP_LAYER_LST* nil) ) ;_ end of defun (defun mip:layer-status-save () (setq *MIP_LAYER_LST* nil) (vlax-for item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) (setq *MIP_LAYER_LST* (cons (list item (cons "freeze" (vla-get-freeze item)) (cons "lock" (vla-get-lock item)) ) ;_ end of cons *MIP_LAYER_LST* ) ;_ end of cons ) ;_ end of setq (vla-put-lock item :vlax-false) (if (= (vla-get-freeze item) :vlax-true) (vl-catch-all-apply '(lambda () (vla-put-freeze item :vlax-false)))) ) ;_ end of vlax-for ) ;_ end of defun (defun ChangeAllObjectsColor (Doc Color ) (vlax-for Blk (vla-get-Blocks Doc) (if (= (vla-get-IsXref Blk) :vlax-false) (vlax-for Obj Blk (if (vlax-property-available-p Obj 'Color) (vla-put-Color Obj Color) ) ) ) ) ) (defun C:CX ( / doc col) (vl-load-com) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc) (mip:layer-status-save) (if (setq col (acad_colordlg 7 t)) (ChangeAllObjectsColor doc col);_ col � color number ) (mip:layer-status-restore) (vla-endundomark doc) (princ) ) (princ "\nType CX in command line") ==UNQUO== Edited December 3, 2020 by SLW210 Add Code Tags Quote
BIGAL Posted December 4, 2020 Posted December 4, 2020 Ok so say change Lines, plines on layer abc correct ? Need to know which objects to change ? Could be like type "Line" or "*line" plines & Lines or "line Arc Circle" and so on. Quote
pkenewell Posted December 4, 2020 Posted December 4, 2020 (edited) Note: The routine you submitted updates just objects in block definitions, not inserts or other objects. If that is what you actually want, the solution is simple: Change the following line in the "ChangeAllObjectsColor" function: (if (vlax-property-available-p Obj 'Color) To (if (and (vlax-property-available-p Obj 'Color)(= (vla-get-layer obj) "<Your Layer Name Here>")) ;; Replace "<Your Layer Name Here>" with the layer name you need. Edited December 4, 2020 by pkenewell Quote
