I know very little about lisps. I'm kinda playing around with something and I've run in to problems. I want to draw a line between two existing lines that is a certain length.
i start with:
(command "_line" "m2p"
It gives me the option to pick two parts on the screen (i'll choose the two existing lines) and then I'm supposed to select the second point for the line (which I want it to be "@0,-200"). How would I pause for user input after "m2p" but auto insert the above ? Thanks
(command "_line" "m2p" pause pause "@0,-200" "")
Thanks. I knew it was something simple like that. I'm trying to teach myself some basic lisp programming by looking at other lisps I am currently using... I hadn't seen any use "pause" yet.
Pause is a handy one, for a continual pause, try something like this:
(while (> (getvar "cmdactive") 0)(command pause))
Also, remember in macros, a pause is notified by \
