michaeloureiro Posted February 5, 2009 Share Posted February 5, 2009 I´ve just loaded a perfectly working dynamic block in another computer, but the visibility grip turns red instead of working:x . Does anybody know how to fix this? Thanks Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted February 5, 2009 Share Posted February 5, 2009 Grip points will usually turn red while they're being controlled. I suspect that the parameter is set to either increments or a list, and each of these options is significantly larger than what it was on the other system. The most likely cause is a units mix up with the insertion scale. If this isn't the case, can you post the block? Otherwise its like fixing a car over the phone with the other person trying to imitate the "ping!" noise. Quote Link to comment Share on other sites More sharing options...
michaeloureiro Posted February 6, 2009 Author Share Posted February 6, 2009 I imported the block to cad 06. Its seems that the visibility parameter doesn´t working in that version. I opened the block again in cad 07 and it works fine. Quote Link to comment Share on other sites More sharing options...
