Is there a setting to automatically adjust the height of table rows. The adjustment is only made if the height increases, but not if it decreases.
You can reset any row using (vla-SetRowHeight Objtable rownum rowht) you get how many rows then use a repeat to step through the rows.
; (vla-SetRowHeight Objtable row rowht) would change the 3rd row as rows start at 0.
(setq objtable (vlax-ename->vla-object (car  (entsel "\nPick table "))))
(setq rownum (vla-get-rows objtable))
(setq x 0)
(repeat (- rownum 1)
(vla-SetRowHeight Objtable (setq x (+ x 1)) rowht)
Thanks BIGAL, I was asking with respect to a setting.
With the LISP, it's along the same lines as manually adjusting.
The reason is that more often than not, I forget to adjust or as the case may be, run the LISP.
In a similar manner to when the row increases in size, this is done automatically by AutoCAD.
Happy to find out if there is some way to do it looked a couple of times. Its not exposed in properties.
Run Dumpit on  a table like dims a stack of options maybe just one needs to be reset.
Sorry BIGAL but I can't understand what you mean.
Use this pick an object reveals all sorts of stuff. Pick a table and a dim.
;;; DumpIt                                                            ;
;;; Dump all methods and properties for selected objects              ;
(defun C:Dumpit ( / ent)
  (while (setq ent (entsel))
    (vlax-Dump-Object
      (vlax-Ename->Vla-Object (car ent))
OK thanks I tried it, there was a bunch of properties. The relevant one, I'm guessing it's relevant showed nothing.
RowHeight (RO) = ...Indexed contents not shown...
Ok found maybe an answer you need to work out the cell margins. But again by program
(vlax-put Obj 'VertCellMargin 5)
Edited by BIGAL
OK I'm guessing "entmake" is a LISP routine ... to make a Table?
I do see this in there. But if I type "VERTCELLMARGIN", it says unknown command.
VertCellMargin = 1.5
I can't understand what I'm supposed to do with "(vlax-put Obj 'VertCellMargin 5)".
I tried to enter into the command line but nothing works.
OK thats just a std display of the command, the obj is a VL object that has been selected.
(setq obj (vlax-ename->vla-object (car  (entsel "Pick table"))))
Sorry BIGAL you've lost me here.
I tried various things including entering into the command line ... I don't know what happened but the table had all rows with a margin of what is input from above ... so something worked ... but I don't know what I did.
But I still don't understand where the automation comes into it. Is this set and forget?
  • 5 years later...
(defun c:tablefix ()
  (initget 6)
  (setq rowht (getreal "\nRow height <10.0>: "))
  (if (null rowht) (setq rowht 10.0))
  (setq x 0)
  (repeat rownum
    (vla-SetRowHeight objtable x rowht)
    (setq x (+ x 1))
Edited by SLW210
Added Code Tags!!
The row height if using a lisp will auto adjust based on the row text height, I get around this problem by asking for text height as the control in the table I usually make a custom "Table Style" with the desired settings much easier than trying to fix an existing table. You can also define the margins around the text in the style.
Yes do have something.
  • 3 months later...
This won't auto adjust, but to fix an auto increase, Select the entire table, go to Properties, change "Cell Height" to the cell height you want. All rows adjust to defined cell height.
