Lisp to delete everything inside circles
Hi.
I need a lisp routine that deletes all the elements that are inside a circle.
I need to select many circles at the same time.
Please, can you help me?
Give this a try ... welcome to CadTutor!
(defun c:foo (/ _c2p _l a p r s)
  ;; RJP » 2020-12-18
  ;; Deletes items found within a selection of circles
  (defun _c2p (p r n / a i z)
    (setq a 0)
    (setq i (/ (* pi 2) n))
    (repeat n (setq z (cons (polar p (setq a (+ a i)) r) z)))
  (defun _l (s)
    (if	s
      (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  (cond	((setq s (_l (ssget '((0 . "CIRCLE")))))
	 (setq a (vlax-get-acad-object))
	 (foreach e s
	   (setq p (cdr (assoc 10 (entget e))))
	   (setq r (cdr (assoc 40 (entget e))))
	   (vlax-invoke a 'zoomcenter p (* r 2))
	   (foreach b (_l (ssget "_WP" (_c2p p r 100))) (entdel b))
  (progn)
(vl-load-com)
An alternative to _c2p I use is polygon "I" so matches circle probably don't need 100 sides the bigger the number the more accurate as you suggest.
Then use
polygon Briscad is different than Acad
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (entlast)))))
(command "erase" "WP" co-ord "" (entlast) "")
Then use
@BIGAL Why would you use a temp object when these points can be created with easy math?
You are correct, its the algorithm I use a lot as a library solution for say ssget "F" for a circle filter.
