Happy55 Posted February 6, 2009 Posted February 6, 2009 Whats the easiest/quickest way to delete the line (part of a larger rectangle) that my small rectangle runs through. I.e. so I can just have the smaller rectangle without the line running through the middle of it? I found the ERASE function, but it doesn't seem to osnap, so not precise enough. NOTE: The line I want to delete is circled in RED above. Quote
skipsophrenic Posted February 6, 2009 Posted February 6, 2009 Use the TRIM command, select the 2 lines i've circled, press return, then select the line you've circled Quote
