CADman123 0 Posted January 14 I am building 3D models from existing and proposed 2d drawings. Most of the drawings i recieve, the setting out spot marker is either a cross which is 2 exploded lines with intersections or it is a block. I have a lisp routine that moves text to the midpoint of a 'POINT' which will enable me to create an accurate 3d model however this does not work as the spot level markers are usually either blocks or 2d cad lines intersecting. Any help would be appreciated. Quote Share this post Link to post Share on other sites
Jonathan Handojo 125 Posted January 14 A dwg or an image of a "Before and After" would certainly help. Otherwise it's hard to grasp. Quote Share this post Link to post Share on other sites
dan20047 12 Posted January 14 Share your lisp? It may be easy to revise to select block insertion point instead of point location. (Though you said midpoint of point, is that possible?) Also: https://forums.autodesk.com/t5/autocad-forum/change-block-reference-to-points/td-p/6678247 Quote Share this post Link to post Share on other sites
BIGAL 501 Posted January 14 Re 2 lines if they are on a layer and hor and ver then easy to just use say the horizontal and get 1/2 point with a Z that is assuming the lines are at a Z. The block as suggested can use insertion point and adjust X Y if required. Quote Share this post Link to post Share on other sites
