dutch724 0 Posted January 20 (edited) Hi, I am in a need for a batch xref rename lisp routine at a minimum. At this time I am having to open each drawing and rename and repath the xrefs. This will take years. I am not sure on how to make a lisp command, but I know how to load them into AutoCAD. I have hundreds of drawings that need the xrefs renamed and/or repathed. I am looking for a batch lisp command that I could load a bunch of those drawings up at a time and run it. The company has sold and of course they want the new name on all the title block xrefs. I will need to rename the title block name most important. Old name: Building 1 - Titleblock xxxx 24 x 36 New name: Building 1 - Titleblock company name 24 x 36 I can use the reference manager to repath the xrefs in batches. The situation I have right now all the old xrefs go into an archive folder and the new title blocks are outside of that folder. Old title blocks: K:\Engineering\EN Controlled\Drawing Files\AutoCAD Files\Title blocks\archive New title blocks K:\Engineering\EN Controlled\Drawing Files\AutoCAD Files\Title blocks Hopefully, this makes sense. Thank you for your help. Edited January 20 by dutch724 needed to include more details Quote Share this post Link to post Share on other sites
