Panda 10 Posted February 11 Hi, I have a simple point cloud and I would like to turn it into a solid with edges. I was told I could do this with Meshroom which I downloaded, however it will not allow me to import a .dwg, .csv or RCP file so i'm a bit snookered. Does anyone have any suggestions? Any help appreciated. Cheers XYZ Data.rcp Quote Share this post Link to post Share on other sites
Panda 10 Posted February 11 I should add that ultimately I want to bring it into Autocad 2018. That's the only product I use along with Navis Freedom. Quote Share this post Link to post Share on other sites
Panda 10 Posted February 11 Sorry, Meshmixer was the program I downloaded. Quote Share this post Link to post Share on other sites
ammobake 56 Posted February 12 From what I recall you can link your pointcloud data to ARCGis and then export the data in the form of a CSV shapefile. From there it might work in Meshroom - though I've never heard of it personally. There could also be formatting issues with what Meshroom is importing. For example, it might only be able to import specific version DWG's, etc... and it might not be readily apparent. -ChriS Quote Share this post Link to post Share on other sites
BIGAL 526 Posted February 12 You have a RCP look at this https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/screencast/Main/Details/8d78abb9-5f98-4d2f-8e61-d621c4012760.html If you dont have civ3d maybe "Phone a friend" Quote Share this post Link to post Share on other sites
