Well I was asking myself how to cut a number lets say 456.56798 to 3 decimal places, I have tried with (rtos 456.56798 2 3) but then I noticed that it always round up to 456.568, so I did the following
(vl-load-com)
(defun c:IA:cut (/ a b c decimalplaces number)
   (setvar "cmdecho" 0)
   (vl-cmdf "_.undo" "_begin")
   (setq number (getreal "\nType the number to cut: ")
         decimalplaces (getint "\nType the decimal places: ")
         a (atof (rtos number 2 decimalplaces))
         b (- number a)
   (if (or (> b 0) (zerop b))
      (princ (strcat "\nYour new number is: " (rtos a 2 decimalplaces)))
         (setq c (+ (/ 1.0 (expt 10 decimalplaces)) b)
               a (- number c)
   (vl-cmdf "_.undo" "_end")
Just hope it helps you with your programs.
Here are two other possible methods:
(defun f1 ( n p )
    (/ (fix (* n (expt 10 p))) (expt 10.0 p))
_$ (f1 456.56798 3)
456.567
(defun f2 ( n p / d s )
    (setq d (getvar 'dimzin))
    (setvar 'dimzin 0)
    (setq s (rtos n 2 16)
          s (substr s 1 (+ 1 p (cond ((vl-string-position 46 s)) ((strlen s)))))
    (setvar 'dimzin d)
    (atof s)
_$ (f2 456.56798 3)
456.567
Edited by Lee Mac
Thanks Lee, your f1 is much more better.
Edited by Isaac26a
Because it may get missinterpreted
