erik_NL Posted February 8, 2009 Posted February 8, 2009 goodday, i'm having some trouble with plotting of layouts. Al the others functions (not related functions) work but i do have some problems with plotting a layout. My most succesful code is; Dim PlotLayout As AcadLayout Dim PlotLayouts As AcadLayouts ' On Error Resume Next If ThisDrawing.ActiveSpace = acModelSpace Then ThisDrawing.ActiveSpace = acPaperSpace Set PlotLayouts = ThisDrawing.Layouts Else End If On Error Resume Next If PlotLayout.Name <> "Model" Then ThisDrawing.ActiveLayout = PlotLayout ThisDrawing.Plot.PlotToDevice VBA.DoEvents End If the "on error resume next" was one of the last options to test. I copied code from the Help, checked some things out of the Joe Sutphin book, copied code from the plot.dvb from activedwg.com etc etc with no succes. On running this code i get by the second layout (layout2) a unfinished program witch shows a a commandline input request as if something ain't finished (thats the reason for the vba.doevents) Command: Regenerating model - caching viewports. Command: Command: Restoring cached viewports - Regenerating layout. Command: Regenerating layout. Restoring cached viewports - Regenerating layout. I want to batch plot (in first plot one drawing and if succesful batchplot folders) all layouts to a TDS9600 and/or a dwg2pdf plotter. tia. Quote
