jonathann3891 Posted April 13, 2021 Share Posted April 13, 2021 Is it possible to strip the file extension (.dwg) of a selected file using the method I have detailed below? Here I am selecting a block and storing the block name in appdata. (defun c:ttt (/) (setq PileType (getfiled "Select Pile Drawing" "Z:\\ECI CAD\\AutoCAD\\PileDriver\\Pile Data\\" "dwg" 8)) (setcfg "AppData/PileDriver/Pile_Type" PileType) (princ) ) Here I am recalling the name of the block stored in appdata. (defun c:foo (/) (setq PileType (getcfg "AppData/PileDriver/Pile_Type")) (setq bname (??)) ) Is it possible to strip the file extension (.dwg) from PileType and set it as bname? Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted April 13, 2021 Author Share Posted April 13, 2021 I found my answer. Using vl-filename-base will give me the result I'm looking for Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 14, 2021 Share Posted April 14, 2021 You can also use the fnsplitl function: _$ (fnsplitl "C:\\test.txt") ("C:\\" "test" ".txt") 1 Quote Link to comment Share on other sites More sharing options...
