michaeloureiro Posted February 9, 2009 Posted February 9, 2009 Is there an easy way to turn off or isolate selected layers with the filter command? I know i can do basically the same thing with the property filter in the layer manager, but it less of a hassle with one time commands or specific filters... thanks Quote
Dipali Posted February 9, 2009 Posted February 9, 2009 after filter or layiso, select 'turn off layer' from toolbar (layers II) & select object : 'all' should work the trick Quote
michaeloureiro Posted February 9, 2009 Author Posted February 9, 2009 after filter or layiso, select 'turn off layer' from toolbar (layers II) & select object : 'all' should work the trick it works, got the order down wrong, thanks Quote
