Spiderguy Posted February 9, 2009 Posted February 9, 2009 Hello! I have a question, there (at one time) was a command for removing multiple lines that were over (stacked) one another on the same plane. Does anyone know about what I am asking? I can select a line delete it another is there, can delete it, another is there, this can go on and on until the last one is selected. I run into this often, where people who do not use CAD often have done some drawings. There was a tool that fixed the drawing for you, I can't remember what it was called, nor can I seem to find it in AutoCAD help. Thanks, Matt Quote
Spiderguy Posted February 9, 2009 Author Posted February 9, 2009 Thanks! have to use command line now though, not found in express tools drop-down menu. Matt Quote
lpseifert Posted February 9, 2009 Posted February 9, 2009 Express > Modify > Delete duplicate objects If it doesn't seem to work properly, try setting Pickfirst=0 prior to running the command Quote
