Ish Posted April 30, 2021 Posted April 30, 2021 (edited) Dear team, I have many text that I want to convert in attribute and tag name and sequence must be same for all as per source object. I have already make tag name attribute , see inside green cloud. I want keep same tag name and sequence for all text as per source object. Number of tag are fix. See the attached image. For for details. And cad file. Command : select source object for tag : command : select target object for tag : PLAN CURVE TABLE BY LAYER.dwg Edited April 30, 2021 by Ish Modified Quote
