Sir any lisp program for match attributes tag name and prompt name only from source tag to destination tag,
Even one by one, no problem.
I have convert all text in attribute,
But for follow the same tag name , prompt name
I need to match that from source.
I want to match only tag name and prompt only without change text string.
Example :
Source                    target
block 1.                   Block 2.
tag name (a)           tag name (f)
prompt name (a)    prompt name (f)
i want to match only tag name and prompt name from source block  tag to target block tag name only without change text string.
(f) tag name become (a) tag name
(f) prompt name become (a) prompt name
result after match
Source                         target
block 1.                        Block 2.
tag name (a)                tag name (a)
Prompt name (a)         prompt name (a)
thanks in advance
waiting for your good reply.
Edited by Ish
Modified
  • Ish changed the title to Match attribute tag and prompt name only from source to destination
Example :
Source                    target
block 1.                   Block 2.
result after match
Source                         target
block 1.                        Block 2.
thanks in advance
Thanks
