spotted zebra Posted February 9, 2009 Share Posted February 9, 2009 I created a block with a simple polygon and three define attributes of text. I wanted the text centered and 5/16" so thats what I specified. Saved it and inserted it in the drawing, everything worked fine until i drug it into a palette. If i tried inserting it from then on the second text attribute would be right justified. i tried everything i could think of but nothing worked help please. thanks in advance for the help! Quote Link to comment Share on other sites More sharing options...
stevsmith Posted February 9, 2009 Share Posted February 9, 2009 Can you upload the file? It would be easier to find the cause of the problem if we had a cad copy. Quote Link to comment Share on other sites More sharing options...
mxpxh2o Posted February 10, 2009 Share Posted February 10, 2009 Hi, have you tried doing an attsync comand on the block before dragging it? also before you do this you might want to edit block in place and check the properties of your attributes. Hope this helps. Quote Link to comment Share on other sites More sharing options...
spotted zebra Posted February 11, 2009 Author Share Posted February 11, 2009 ok i got it fixed but can you explain to me why this worked. I edited the block to my needs and clicked 'close block editor'. I clicked 'save' when prompted. then in the actual drawing i had to 'INSERT' the block then save the file. I drug it to the tool palette and wa-la it works. Quote Link to comment Share on other sites More sharing options...
dbroada Posted February 12, 2009 Share Posted February 12, 2009 if you change an attribute using BEDIT it only changes FUTURE insertions of the block. You have to ATTSYNC the block to update all previous insertions too. Your toolpalette seems to have been copying an old definition of the block rather than the newly redefined one. Quote Link to comment Share on other sites More sharing options...
