aridzv Posted May 29, 2021 Posted May 29, 2021 (edited) Hi. I found a lsp from lee mac that used to change attribute width for all the blocks attributes in a drawing, and I modify it to change the attribute text size. I need help with 3 issues: 1. the most important is to be able to select a group of blocks to apply this change and not to all the blocks in the drawing. 2. to be able to assign the text size (need the lsp to prompt the user to choose the size). at the moment I need to open the lsp file and change the value there. in the attached lsp file I've tried to do it but I get an error that I fail to solve... this is the error: "; error : bad argument type <ASSOC> ; expected <INTEGER> at [invalid DXF/XED data]" 3. to select a specific attribute (Tag name) to change. I need to change tag that call "ORDER", and I need to set it in the lsp, no need to prompt the user to choose it. thanks, Ari. *EDIT: here is a sample DWG: attw11.lsp Drawing1.dwg Edited June 1, 2021 by aridzv Quote
devitg Posted May 31, 2021 Posted May 31, 2021 maybe it could help use this ssget (setq s (ssget '((0 . "INSERT") (66 . 1)))) and (assoc 40 . sz) sz.0 is not a INTEGER neither a variable Quote
BIGAL Posted May 31, 2021 Posted May 31, 2021 You have this posted else where and I offered a start solution on that forum. How to change attribute text size of multiple blocks? - BricsCAD Forum (bricsys.com) re questions asked there all the answers are in the code posted need subtle changes. Can add rotation similar to height request, remove the bname from ssget code. Quote
aridzv Posted June 1, 2021 Author Posted June 1, 2021 20 hours ago, devitg said: maybe it could help use this ssget (setq s (ssget '((0 . "INSERT") (66 . 1)))) and (assoc 40 . sz) sz.0 is not a INTEGER neither a variable @devitg I tried it, but I'm getting errors. this the code I'm trying: (defun c:attw141 ( / e i s x sz ) (if (null(setq sz (getdist "\nText size: "))) (setq sz "5")) (if (setq s (ssget "_X" '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength s)) (setq e (entnext (ssname s (setq i (1- i)))) x (entget e) ) (while (= "ATTRIB" (cdr (assoc 0 x))) (or (equal 1.0 (cdr (assoc 40 x)) 1e-8) (entmod ((assoc 40 sz) (assoc 40 x) x)) ) (setq e (entnext e) x (entget e) ) ) ) ) (princ) ) and this is the error I'm getting: ; error : bad argument type <12.0> ; expected <LIST> at [assoc] what am I doing wrong here? Quote
BIGAL Posted June 1, 2021 Posted June 1, 2021 For anyone else, what I posted. (defun c:chatht ( / bent bent2 pt lay tagname ss bname x att) (setq bent (nentsel "\Pick attribute")) (setq pt (cadr bent)) (setq bent (entget (car bent))) (setq lay (cdr (assoc 8 bent))) (setq tagname (cdr (assoc 2 bent))) (setq bent2 (ssname (ssget pt ) 0)) (setq bname (cdr (assoc 2 (entget bent2)))) (setq ss (ssget (list (cons 0 "INSERT") (cons 2 bname)))) (setq ht (getreal "\nEnter text height ")) (repeat (setq x (sslength ss)) (foreach att (vlax-invoke (setq obj (vlax-ename->vla-object (ssname SS (setq x (- x 1) )))) 'getattributes) (if (= tagname (strcase (vla-get-tagstring att))) (vla-put-height att ht) ) ) ) (princ) ) (c:chatht) Quote
aridzv Posted June 2, 2021 Author Posted June 2, 2021 (edited) @BIGAL I tried your code on the drawing attached here, and it raise an error: ; error : bad argument type <NIL> ; expected SELECTIONSET at [sslength] about the sample drawing I've attached here: the drawing has 3 inserted blocks, and all the blocks have a number of attributes. only one attribute is visible, the one with Tag name "ORDER", and this is the attribute that I need to change its text size and rotation For a selected groups of blocks, and if it is a problem so for all the blocks in the drawing. for example - I need all the attributes with Tag Name "ORDER" to have text size of 24 and rotation angle of 0. Drawing1.dwg Edited June 2, 2021 by aridzv Quote
BIGAL Posted June 3, 2021 Posted June 3, 2021 Hard coded (defun c:chatht2 ( / bent bent2 pt lay tagname ss bname x att) ;(setq bent (nentsel "\Pick attribute")) ;(setq pt (cadr bent)) ;(setq bent (entget (car bent))) ;(setq lay (cdr (assoc 8 bent))) ;(setq tagname (cdr (assoc 2 bent))) (setq tagname "ORDER") (setq ss (ssget (list (cons 0 "INSERT")))) (setq ht (getreal "\nEnter text height ")) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname SS (setq x (- x 1) )))) (if (= (vla-get-hasattributes obj) :vlax-true) (foreach att (vlax-invoke obj 'getattributes) (if (= tagname (strcase (vla-get-tagstring att))) (vla-put-height att ht) ) ) ) ) (princ) ) Quote
aridzv Posted June 4, 2021 Author Posted June 4, 2021 @BIGAL THANKS!!! works bountifully!! based on your previous advises I have made some additions to the code (see attached lsp file). and again - thank you for your guidance!! Ari. chatht15.lsp Quote
