View Objects without associated model
NealsCNC
Hello, I run a CNC shop and use AutoCAD to set up our cuts.  I have never worked with views or layouts at all, we stick strictly to the Model area.
I just got some drawings from a customer that only seem to contain content in a Layout view.  The layouts contain a "view object" which is what I need to cut, only I cannot figure out how to get the shape out of that object.  It won't explode or copyclip.
Anyone have any ideas?  The only information I can find online is how to make view objects from a model.  Nobody is talking about how to do that in reverse!
Thanks,
Rachel
Link to post
BIGAL
Post dwg so people can look at it.
In model what happens when you do UCS W, PLAN then Zoom E can you see object
Edited by BIGAL
Link to post
ammobake
The object may be in model space but either on a frozen or off layer too.
you can try turning on all layers, ensuring nothing is frozen, and then zoom to extents.  See what shows up (if anything).
My recommendation is start there.
-ChriS
Link to post
NealsCNC
Thanks for the suggestions.  There are no objects I can find on any layers in model space, all the layers are visible and unfrozen.  Here is one of the DWG's.
Best,
Rachel
Pint Long Side v1.dwg
Link to post
SLW210
Those are Drawing Views from Fusion, use Export Layout (Right-Click the Layout Tab) to create a new .dwg and it will be a block that can be exploded. I think it will need scaled as well.
Link to post
