Remove Negative from Longitude
I am trying to figure how to (not show) the negative (-) within the Longitude value.
Example:
Latitude 56d 42' 22"
Longitude -82d 21' 26"
Thank you for the help!
; Convert Decimal Degrees to dms.
(defun convertDDdms (x1 / deg mins sec)
  (setq deg (rtos (fix X1) 2 0)                                    ;- degrees
        mins (rtos (abs (fix (* (- X1 (fix X1)) 60))) 2 0)         ; - minutes
        sec (rtos (abs (* (- (* X1 60) (fix (* x1 60))) 60)) 2 2)  ;- seconds
  (strcat deg "d " mins "' " sec "\"")
(defun c:Coords	(/ as_cor ll lat lon pnt)
  (setq as_cor (ade_projgetwscode))
  (if (/= "" as_cor)
      (ade_projsetsrc as_cor)
      (ade_projsetdest "LL84")
      (while (not  (setq pnt (getpoint "\nSelect a point: "))))
	(setq ll (ade_projptforward pnt))
	(setq lat (car ll)
	      lon (car (cdr ll))
	(setq desc (ade_projgetinfo "LL84" "description"))
	(alert (strcat "Conversion:"
                       "\n "
		       "\nLatitude:" (convertDDdms lon)
                       "\nLongitude: " (convertDDdms lat)
                       "\nHorz Datum: NAD83"
    (asg_coor)
Link to post
Didn't you post this awhile ago? I took out the neg for the mins and sec but degrees it needs to be kept if your working in the southern hemisphere.
change the following
to
(setq deg (rtos (abs (fix X1)) 2 0)
then it will always be positive.
Edited by mhupp
put abs in the wrong place
Link to post
Yup you are right. I finally got back to it.
Thank you for showing me this. However, I am getting an error
  ;;(setq deg (rtos (fix X1) 2 0)
    (setq deg (abs (rtos (fix X1) 2 0))                                    ;- degrees
command: Select a point: ; error: bad argument type: numberp: "40"
When I tried to match the below code.
    (setq deg (rtos (abs (fix X1) 2 0)) ;;<<<---                                   ;- degrees
command: Select a point: ; error: too many arguments
Link to post
Example:
Your position is ambiguous.
How will others know whether you are North or South of the Equator, or even West or East of the Prime Meridian?
Link to post
The error isn't with convertDDdms
its most likely here in the function ade_projptforward when it sets the lat and lon
	(setq lat (car ll)
	      lon (car (cdr ll))
my guess its setting them as strings and not integers or doubles because that error is saying "40" isn't a number.
"40" is a number to humans but its in string value so the program cant add, subtract, multiple, or divide it until you convert it into an real
Test the following and see the difference
(defun c:CooWnumbers (/ as_cor ll lat lon pnt)
  (setq lat -82.16197462765378
        lon 56.07939295460651
                 "\n "
(defun c:CooWstring (/ as_cor ll lat lon pnt)
  (setq lat "-82.16197462765378"
        lon "56.07939295460651"
                 "\n "
Edited by mhupp
Link to post
The CooWstring seems to generate an error.
Command: CooWstring
; error: bad argument type: numberp: "56.07939295460651"
Command: CooWnumbers
Did pop with the alert box and no errors.
Link to post
Command: CooWstring
 CooWstring = Coords with String values
like i said your other function is probably setting string values instead of integer values.
in lisp
"56.07939295460651" = string
56.07939295460651 = integer
you could try the following but not 100% it would work
(setq lat (atof (car ll))
      lon (atof (car (cdr ll)))
Edited by mhupp
Link to post
Like you said earlier, is it as simple a converting the string over to an interger?
Something similar to this? I basically just added the atoi into the setq.
  (setq lat (atoi "-82.16197462765378")
        lon (atoi "56.07939295460651")
                 "\n "
Link to post
                 "\n "
looked it up atoi only sets whole numbers you want to use atof so it will set everything after the .
lat (atoi "-82.16197462765378")  lat = -82
lat (atof "-82.16197462765378")  lat = -82.16197462765378
Link to post
Ok. So if I use the (atof) function. I should be able to apply what you mentioned above.
  (setq lat (atof "-82.16197462765378")
        lon (atof "56.07939295460651")
to this.
Then getting the following:
Command: coowstring
; error: bad argument type: numberp: "56"
Command:
Link to post
abs needs to wrap fix x1
(setq deg (rtos (abs (fix X1)) 2 0)  ;- degrees
also its still saying "56" that is a string. if your not reloading the lisp its running the old code quickest way to fix it is to open up windows explorer to where the lisp file is and drag it into AutoCAD you will get a load message and will be running the latest code.
Edited by mhupp
Link to post
BOOM! Got it! Thank you for your time, help and explanation. I m sorry if it seems like I was chasing my tail around and around.
This works.
                 "\n "
                 "\n "
Edited by rcb007
Link to post
This works.
Thats just a stripped down code so i could run it on my end. you need to update your original code with the changes to see if it really workds
Link to post
This is what I have. It seems like it works with what we have talked about.
  (if (/= "" as_cor)
	(setq lat (car ll)
	      lon (car (cdr ll))
                       "\n "
    (asg_coor)
Link to post
Jonathan Handojo
(defun convertDDms (n)
    (strcat
	(rtos (fix (setq n (abs n))) 2 0) "d "
	(rtos (fix (setq n (* (- n (fix n)) 60))) 2 0) "' "
	(rtos (* (- n (fix n)) 60) 2 2) "\""
If negative doesn't matter, you can avoid all the 'abs' by setting it in the beginning first.
Edited by Jonathan Handojo
Link to post
