Cadder Posted February 10, 2009 Posted February 10, 2009 I changed themes in Windows and my buttons stayed the same color as my previous theme. What can I do to get the buttons to be what ever color my theme is without opening each and every last button image and making its background image transparent? Note: I'm not using any custom buttons. All buttons are standard Autocad buttons. Quote
Tiger Posted February 10, 2009 Posted February 10, 2009 is it really meant to change? Don't know if the Windows theme is meant to reflect onto the toolbar buttons in AutoCad... Quote
Cadder Posted February 10, 2009 Author Posted February 10, 2009 All I know is that when I installed Autocad I was using the Windows XP Olive Theme and it took on the yellowish/greenish colors of that theme. I've since changed to a gray and black theme and the backgrounds of the buttons are still showing the yellowish/greenish color. I'm not wanting the shapes or styles of the buttons to change, just the background color, so that it blends smoothly. If you look at the below screen shot, you can see the yellow/greenish color on the button images I'm referring to. Quote
Tiger Posted February 10, 2009 Posted February 10, 2009 I'll add a pic of my AutoCAD to compare colors - but I think that the color you have there is the normal color of AutoCAD and it won't change. Please, someone, correct me if I'm wrong. Quote
Cadder Posted February 10, 2009 Author Posted February 10, 2009 Ah, I see what you mean. It must've been so close to the other theme, that I didn't notice the difference. Thanks! Quote
