nolex Posted June 20, 2021 Share Posted June 20, 2021 I need a lisp code that will extract information from a block attribute and dimension and put them into a table And another code to manually edit a table just in case to do type in something into the table. Or if they can put into one program that will be great. Wish I could write codes but Lee Mac has been my source of all my LISP programs but I just couldn't find everything I need for my job. For reference, I have included a snapshot of what I'm working on. Thanks Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted June 21, 2021 Share Posted June 21, 2021 Would a Bill of Materials tool work for you? Vanilla AutoCAD doesn't include one, but there are ways to do the same thing (see this KB page). Once you've extracted the data, you can import it as a table, which you can edit as needed. Not sure how you'd extract dimension data, unless it was part of a dynamic block. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 22, 2021 Share Posted June 22, 2021 There is a massive amount of block or dim to a table just google. You will probably find they are seperate. You need to post a sample dwg with dims and blocks which ones you wnat, also need a example table that you want. Quote Link to comment Share on other sites More sharing options...
