I am trying to create an annotative dynamic block with attributes. I need to be able to flip the lower boxes with attribute text up to be below/hidden behind the upper boxes with attribute text for a finish schedule. I need to be able to select which ones are viewable not an entire row. When I flip one box it only flips the left attribute text and the selected box, no matter which flip action you choose. The box will flip fine, and hids perfectly. Also the draw order is not working either. I need the flipable text to remain hidden unless it is flipped below the upper boxes.
Any help would be helpful. I have attached the dwg file for your use.
FINISH1.dwg
Ok, let me just ask these questions........
1) When you have a flip action in a dynamicblock, can you have a different attribute flip with each action, or is it only going to flip the first attribute you select?
2) Can you hide an attribute behind a wipe out that is inside the dynamic block after it has been flipped?
3) Is my idea even feasable in this type of block?
4) Can anybody tell me why I try to do stuff like this?:cry:
  • 2 weeks later...
sorry, but I need to bump this.
Any and all help please8)
