Good Afternoon:
Does anyone one have an attributed text editor without the dialog box popping up?
I used to have a lips that I could type AT and then click on the attributed text. The Attributed text  would look like D text format for editing instead of the Enhanced attribute Editor box popping up. It saved a few steps.
for me on Bricscad the command DDATTE brings up a simplified attribute editor
If I'm honest, I didn't see that much of a saving. If you only need to change the text of the attribute, just click on it and the relevant text will be highlighted. Finally, the usual OK in the dialogue box, but you have to press ENTER even if you don't have the window. It is a different case if you need to change the characteristics of the attribute, but then you have to use the advanced editor.
Try Ctrl+Double-clicking the attribute.
By default settings it should work.
Ctrl+Pick works great for selecting subentities.
See 2nd post in this thread by Keith™
Steve
Edited by StevJ
spellin
This is the simple way as suggested by Tombu above: -
Or you could just use the AutoCAD command  ATTIPEDIT
  • 2 months later...
THANK YOU  TOMBU & MANILA WOLF!!!
For me it is a huge time saver. We use add on software that has the enhanced attribute editor Autocad editing popping up way too much for me. this is a huge time saver.
Ctrl+Double-clicking the attribute or
Edit Block Attributes
ATTIPEDIT 4
(defun c:4()
(command "ATTIPEDIT"))
Edited by Efeezy
