ERROR IN AUTOCAD 2010
 I CONVERT  A DWG 3D FILE FROM 2018 TO 2010, THIS ERROR NOTICE HAPPENS WENT I OPEN THE FILE IN AUTOCAD 2010 WHILE TRYING TO RENDERED.
Link to post
Cad64
So, you can open the file, correct? The error pops up when you try to render?
I don't know what that unhandled exception is. It could be just about anything.
Your profile says you're using 2022. Can you render the file in that version without getting the error?
Is it a big file?
How much RAM do you have installed?
Have you tried running an Audit to see if there are any errors in the file?
If you have 2022  installed, why are you trying to render in 2010? Just curious.
The problem could be from when you saved the 2018 file down to 2010 format. Autodesk changes the file format every 3 years or so, so maybe there's an issue with saving the file back to an earlier format?
Link to post
