I was looking around and found the Hatch to Back (by Mr. Lee Mac) which does a great job. I did not know if anyone may have seen one which worked with predefined layer names or not.
(defun c:test ( / acblk acdoc acsel name obj processed )
 ;; Lee Mac 17.06.11
 (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
       acblk (vla-get-blocks acdoc)
 (if (ssget '((0 . "INSERT")))
     (vlax-for block (setq acsel (vla-get-activeselectionset acdoc))
       (if (not (member (setq name (vla-get-name block)) processed))
           (lambda ( / lst )
             (vlax-for obj (vla-item acblk name)
               (if (eq "AcDbHatch" (vla-get-objectname obj))
                 (setq lst (cons obj lst))
             (if lst
               (vla-movetobottom (LM:SortentsTable (vla-item acblk name))
                 (vlax-make-variant
                   (vlax-safearray-fill
                     (vlax-make-safearray vlax-vbobject (cons 0 (1- (length lst)))) lst
             (setq processed (cons name processed))
     (vla-delete acsel)
     (vla-regen  acdoc acallviewports)
(defun LM:SortentsTable ( space / dict result )
 (cond
     (not
       (vl-catch-all-error-p
         (setq result
           (vl-catch-all-apply 'vla-item
             (list (setq dict (vla-GetExtensionDictionary space)) "ACAD_SORTENTS")
     result
   ( (vla-AddObject dict "ACAD_SORTENTS" "AcDbSortentsTable") )
(vl-load-com) (princ)
