if find blockname - delete block
Manuel_Kunde
On 8/24/2021 at 12:01 PM, yxl030 said:
To See if this is what you want
http://www.lee-mac.com/deleteblocks.html
I'm looking for something like that. But I can't get it work right now. In some drawings I have a block that I want to delete if it is there (via lisp).
;;; Purge named block
;;; Example: (ax:purge-block (vla-get-activedocument (vlax-get-acad-object)) "testblock")
;;; Argument: doc {document}
;;;           name {a block name}
;;; Return values: T if successful, nil if not successful
(defun c:deletetestblock ()
    (defun ax:purge-block (doc name)
      (if (vl-catch-all-error-p
            (vl-catch-all-apply
              'vla-delete
              (list (vl-catch-all-apply
                      'vla-item
                      (list (vla-get-blocks doc) name)
        nil ; name cannot be purged or doesn't exist
        T ; name purged
Load the lisp. type delblocks it will allow you to pick a block. if you choose the name option it will open a menu to pick the names out of a list. if your drawing has alot of blocks use the filter at the bottom to narrow the list of blocks that contain whats in the filter.
in your lisp im guessing you just want to automatically purge it when you open a drawing?
add a vl-load-com to that bad boy and you should be good.
(ax:purge-block (vla-get-activedocument (vlax-get-acad-object)) "BLOCKNAME")
Thanks for your quick reply, but I don't get it.
I want to delete the block without user input, so when I write the command "deletetestblock", the "testblock" should be deleted.
        (vl-catch-all-apply
          'vla-delete
                  'vla-item
    T ; name purged
  (vl-load-com)
Load lee's and use the following
(defun C:deletetestblock ()
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (LM:deleteblocks doc '("testblock"))
Edited by mhupp
