Martien Posted September 7, 2021 Share Posted September 7, 2021 I have AutoCAD 2022 running on 2 machines, on one machine, my scripts don't run properly at the leader command: The part of the script is this: _LEADER 0,0 2,-2 _A 134755.7,416817.63 When I copy these lines to the command line, it works fine, the leader is drawn. The command line shows this: Command: _LEADER Specify leader start point: 0,0 Specify next point: 2,-2 Specify next point or [Annotation/Format/Undo] <Annotation>: _A Enter first line of annotation text or <options>: 134755.7,416817.63 However, when I run the same lines as part of a scriptfile, the 'or [Annotation/Format/Undo] <Annotation>:' does not appear and '_A' gives an error: Command: _LEADER Specify leader start point: 0,0 Specify next point: 2,-2 Specify next point: _A [Comment: After Specify next point, the or [Annotation/Format/Undo] <Annotation>: should appear ] Invalid Input. Specify next point: 134755.7,416817.63 Then all goes wrong.... On the other PC, the same script works fine. Does anyone know if there is a way to change the script setting, so that both machines work the same way? Quote Link to comment Share on other sites More sharing options...
tombu Posted September 7, 2021 Share Posted September 7, 2021 Quote Link to comment Share on other sites More sharing options...
