Hi, everyone
I am trying to draw a simple graph with lisp, but with very small lengths values, start points are the previous ones
can anybody help?
(defun c:simp ()
(setq start (getpoint "\n select point"))
(setq n (getint "enter n:"))
(setq deltalist nil)
(repeat n
(setq delta (getdist "/lengths"))
(setq deltalist (append deltalist (list delta)))
(setq ct 0)
(repeat n
(setq deltax (nth ct deltalist))
(setq pt1 (list (+ (car start) deltax) (cadr start)))
(setq pt2 (list (+ (car start) deltax) (+ (cadr start) 3)))
(command "line" start pt1 "")
(command "line" pt1 pt2 "")
(setq ct (+ 1 ct))
Edited by CADTutor
Code moved to code block
and what do you want the graph to look like?
You might have written the perfect code to draw this graph, but i suspect it isn't the one you want it to draw.. maybe if you can attach a file showing an example,
The obvious missing is setting "osmode" your home work,  else you may end up with zero length lines as osnap will cause problems snapping points when you dont want them to.
Y= 4x^2 + 3X + 5
