meinfilel Posted September 22, 2021 Share Posted September 22, 2021 Hello, everyone. I'm writing this lsp in order to offset only one side of the polyline and not all of the lines. I'm attaching the code below as well as a gif showing my intended use. As you probably know, while offsetting an object when you are called to choose a side, you get a preview of the new line. That is happening when I'm calling offset from my lisp file. My second problem, is about undo. The last two command of my lsp file are 1)the actual offset command 2)entdel to delete the "buffer line"; I call buffer line just the segment of the polyline I want to offset. What I need to achieve is after completing the program, when undo is called only the offset command gets cancelled. Because the way I got it now (group the last two command) when undo is called entdel is reversed, so I get the "buffer line", which I don't want at all to exist. Any idea of doings thing differently, or a solution to my issues, will be appreciated very much.\ Thanks in advance. Gif code: (defun c:dd ( / ent testpoint thisdrawing k firstvertex secondvertex verlister smallangle linemaker linetodelete pairvertices LM:Unique ) (vl-load-com) ;;==subroutines==;; (defun LM:Unique ( l ) ;remove duplicates --lee mac http://www.lee-mac.com/uniqueduplicate.html-- (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l))) ) ) ) (defun drwpoint ( pnts colorflag / pnt n k mkpoint ) ;; nil doesnt work!!! ;DRAW POINTS WITH FED X,Y (IT MAKES Z = 0 FOR ALL FED POINTS) ;gets as input 2 or 3 coordinates ;in case the fed point has 3 coordinates, it keeps only X and Y ;; ( x y z ) -> slist ;; ( (x1 y1 z1) (x2 y2 z2) ) -> clist ;; ( ( (x1 y1 z2) (x2 y2 z2) ) ( (x3 y3 z3) (x4 y4 z4) ) ) -> sclist (defun mkpoint ( xy clr ) (if (eq (length xy) 3) (setq xy (list (car xy) (cadr xy))) ) (entmakex (list (cons 0 "point") (list 10 (car xy) (cadr xy) 0) (cond ;condition for color ((eq (substr (strcase clr) 1 1) "R") (cons 62 1)) ((eq (substr (strcase clr) 1 1) "Y") (cons 62 2)) ((eq (substr (strcase clr) 1 1) "G") (cons 62 3)) ((eq (substr (strcase clr) 1 1) "C") (cons 62 6)) ((eq (substr (strcase clr) 1 1) "P") (cons 62 6)) ((eq clr "nil") ) ) ;cond ) ) ) ;defun mkpoint (command "UNDO" "BE") ;undo from this point will undo everything (cond ( (eq (elementorlist pnts) "slist") (mkpoint pnts colorflag) ) ( (eq (elementorlist pnts) "clist") (foreach n pnts (mkpoint n colorflag)) ) ( (eq (elementorlist pnts) "sclist") (foreach n pnts (foreach k n (mkpoint k colorflag))) ) ) ;cond (command "UNDO" "END") ) ;defun drawpoint ;;================================================================================;; ;;================================================================================;; ;;================================================================================;; (defun elementorlist ( pnts ) ;;; takes as argument one of the following ;;; and returns the corresponding message ;;; !! a and b must be numbers !! ;;;- a or (a)-> elmnt (single element) ;;;- (a b) -> slist (simple list) ;;;- ( (a b) (c d)) -> clist (complex list) ;;;- ( ( (a1 b1) (a2 b2) ) ( (c1 d2) (c2 d2) ) ) -> sclist (super complex list) (vl-load-com) (if (numberp pnts) ; to check if is REAL or INTeger ;(or (eq (type pnts) (READ "INT")) ;(eq (TYPE X) (READ "REAL")) ) ;OR (setq pnts (list pnts)) (princ) ) (cond ( (AND (eq (length pnts) 1 ) (vl-every '(lambda (x) (numberp x) ;(or (eq (TYPE X) (READ "REAL")) ;(eq (TYPE X) (READ "INT")) ) ;OR ) pnts) ) ;AND "elmnt" ) ( (vl-every '(lambda (x) (numberp x) ;(or (eq (TYPE X) (READ "REAL")) ;(eq (TYPE X) (READ "INT")) ;) ;or ) pnts) "slist") ( (AND (vl-every '(lambda (x) (listp x) ;(eq (TYPE X) (READ "list")) ) pnts ) (vl-every '(lambda (x) (listp (car X)) ;(eq (TYPE (car X)) (READ "list") ) ) pnts ) ) ;AND "sclist" ) (T "clist") ) ;cond ) ;defun elementorlist ;;================================================================================;; ;;================================================================================;; ;;================================================================================;; (defun pairvertices ( lst / 1p extrapair ) ;accepts only clist ; make list ( (a b) (c d) (d e) ) -> ; ( ( (a b) (b c) ) ((b c) (c d) ) ( (c d) (d e) (e a)) (if (eq (elementorlist lst) "clist" ) (progn (if (eq (length lst) 2) ;if only two points are in the vertices list, do nothing pts (progn (setq extrapair (list (last lst) (car lst)) ) (repeat (- (length lst) 1) (setq 1p (append 1p (list (list (nth 0 lst) (nth 1 lst))) ) ) (setq lst (cdr (member (nth 0 lst) lst))) ;read from here ) (setq 1p (append 1p (list extrapair)) ) 1p ) ;progn if vertices list has more than 2 points ) ;if ) ;progn if clist is fed (progn (princ "\nWrong Input. Exiting.") (exit) ) ;progn in anything but clist is fed ) ;if ) ;defun pairvertices ;;================================================================================;; ;;================================================================================;; ;;================================================================================;; (defun vertlister ( arrowpline / pts titty ) ;subfunction making list with vertices of pline ;input -> entity name (setq titty (entget arrowpline)) (while (assoc 10 titty) (setq pts (append pts (list (cdr (assoc 10 titty))))) (setq titty (cdr (member (append (list 10 ) (last pts)) titty))) ) ;while (if (> (length pts) (length (lm:unique pts)) ) ;if true then pline isn't closed ;note: a pline can have overlapping vertices and still be open, not closed (lm:unique pts) pts ) ;if ) ;defun vertlister (defun Linemaker (p1 p2) ;subroutine to make line (entmakex (list (cons 0 "LINE") (cons 8 "wontbeprinted") (cons 10 p1) (cons 11 p2) ))) ;linemaker ;;================================================================================;; ;;================================================================================;; ;;================================================================================;; ;;================================================================================;; (defun smallangle ( pt1 pt2 / ang1 ang2 ) ;gets two points as input ;it returns the smallest angle between them (setq ang1 (angle pt1 pt2) ang2 (angle pt2 pt1) ) (if (< ang1 ang2) ang1 ang2 ) ;if ); defun smallangle ;;================================================================================;; ;;================================================================================;; ;;==subroutines==;; (if (eq ;check that selection is polyline (cdr (assoc 0 (entget (car (setq ent (entsel "Pick line segment to offset."))) ) ) ) "LWPOLYLINE" ) (progn (setq ;ent (entsel "Pick line segment to offset.") testpoint (vlax-curve-getclosestpointto (vlax-ename->vla-object (car ent)) (cadr ent) ) ) (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object))) ;used in vl-startend undo mark commands ;following loop returns the two vertices of pline ;that have the smallest angle against testpoint ;ie vertices of pline which are in a straight line ;passing from testpoint (foreach k (pairvertices (vertlister (car ent))) (if (equal (smallangle testpoint (car k)) (smallangle testpoint (cadr k)) 0.001) ;eq (setq nearestpt k) ) ;if ) ;foreach (setq firstvertex (car nearestpt) secondvertex (cadr nearestpt)) (setq linetodelete (linemaker firstvertex secondvertex)) ;(vla-startundomark thisdrawing) (command "._UNDO" "_Begin") (drwpoint nearestpt "y") ; == debugging (command "_.offset" "_non" pause linetodelete "_non" pause ; select side "" ;exit offset command ) ; end command ;(vla-endundomark thisdrawing) ;delete buffer line (entdel linetodelete) (command "._UNDO" "_End") ) ;progn if LWPOLYLINE (progn (princ "\nNo polyline selected. Consider using build-in offset command.") (princ) ) ;progn ) ;if ) Quote Link to comment Share on other sites More sharing options...
meinfilel Posted September 22, 2021 Author Share Posted September 22, 2021 Well, I should have taken a step back before asking about the undo situtation. The most straightforward solution is to include the creation of the line in the undo group. Quote Link to comment Share on other sites More sharing options...
mhupp Posted September 22, 2021 Share Posted September 22, 2021 For the preview check out the following. This is how to undo multiple commands with one undo. undo with vla looks like these are used in your lisp. you need to move these lines of code to an earlier spot. (Setq thisdrawing (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark thisdrawing) (vla-endundomark thisdrawing) unfo with command (vl-cmdf "_.Undo" "Be") ;set the beging of undo (vl-cmdf "_.Undo" "E") ;set the end of undo 1 Quote Link to comment Share on other sites More sharing options...
tombu Posted September 22, 2021 Share Posted September 22, 2021 These threads may be helpful: and http://www.cadtutor.net/forum/showthread.php?92673-Offset-only-a-section-of-a-closed-polyline&p=634498#post634498#9 1 Quote Link to comment Share on other sites More sharing options...
tombu Posted September 22, 2021 Share Posted September 22, 2021 For creating parcels from polylines for a set area for surveyors this lisp is the bomb! https://www.cadtutor.net/forum/topic/70140-lisp-to-scale-by-moving-only-one-side/page/2/?tab=comments#comment-563855 1 Quote Link to comment Share on other sites More sharing options...
meinfilel Posted September 22, 2021 Author Share Posted September 22, 2021 Thanks you both for your responses, I got some very good ideas about what features I can add. Although, I can't see to find solution regarding the offset command not showing a preview. Quote Link to comment Share on other sites More sharing options...
