JudiHughes Posted September 29, 2021 Posted September 29, 2021 Hi all, I have this lisp routine I downloaded from the web but it is in imperial dims and I need it to be metric meters to 3 decimal points the angles are in degrees and fine. Not great with lisp so any help appreciated. Â Judi DimPline.lsp 1 Quote
confutatis Posted September 29, 2021 Posted September 29, 2021 (edited) (defun c:DimPline2 ( / adoc space obj_dim obj_angdim height_dim pl ent obj dxf_ent ll ur dir_pt base_pt dir_ang last_pt pr_pt lst_pt nw_obj) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) space (if (= 1 (getvar "CVPORT")) (vla-get-paperspace adoc) (vla-get-modelspace adoc) ) obj_dim (vla-add (vla-get-Dimstyles adoc) "DIMPLINE") obj_angdim (vla-add (vla-get-Dimstyles adoc) "DIMANGPLINE") ) (vla-put-activedimstyle adoc obj_dim) (initget 6) (setq height_dim (getdist (getvar "VIEWCTR") (strcat "\nHeight of dim text <" (rtos (getvar "DIMTXT")) ">: "))) (if height_dim (vla-setvariable adoc "DIMTXT" height_dim) (setq height_dim (getvar "DIMTXT"))) (mapcar '(lambda (data_list / ) (vla-setvariable adoc (car data_list) (cdr data_list))) (list (cons "DIMPOST" "") (cons "DIMAPOST" "") (cons "DIMSCALE" 1.0) (cons "DIMASZ" (getvar "DIMTXT")) (cons "DIMEXO" (/ (getvar "DIMTXT") 2.54)) (cons "DIMDLI" 0.38) (cons "DIMEXE" (/ (getvar "DIMTXT") 2.54)) (cons "DIMRND" 0.0) (cons "DIMDLE" (/ (getvar "DIMTXT") 2.54)) (cons "DIMTP" 0.0) (cons "DIMTM" 0.0) (cons "DIMCEN" 0.09) (cons "DIMTSZ" 0.0) (cons "DIMALTF" 25.4) (cons "DIMLFAC" 1.0) (cons "DIMTVP" 0.0) (cons "DIMTFAC" 1.0) (cons "DIMGAP" (/ (getvar "DIMTXT") 2.00)) (cons "DIMALTRND" 0.0) (cons "DIMTOL" 0) (cons "DIMLIM" 0) (cons "DIMTIH" 0) (cons "DIMTOH" 0) (cons "DIMSE1" 0) (cons "DIMSE2" 0) (cons "DIMTAD" 1) (cons "DIMZIN" 0) (cons "DIMALT" 0) (cons "DIMALTD" 2) (cons "DIMTOFL" 1) (cons "DIMSAH" 0) (cons "DIMTIX" 0) (cons "DIMSOXD" 0) (cons "DIMCLRD" 3) (cons "DIMCLRE" 1) (cons "DIMCLRT" 3) (cons "DIMADEC" 2) (cons "DIMDEC" 3) (cons "DIMTDEC" 3) (cons "DIMALTU" 6) (cons "DIMALTTD" 2) (cons "DIMAUNIT" 0) (cons "DIMFRAC" 2) (cons "DIMLUNIT" 2) (cons "DIMDSEP" ".") (cons "DIMTMOVE" 0) (cons "DIMJUST" 0) (cons "DIMSD1" 0) (cons "DIMSD2" 0) (cons "DIMTOLJ" 1) (cons "DIMTZIN" 0) (cons "DIMALTZ" 0) (cons "DIMALTTZ" 0) (cons "DIMUPT" 0) (cons "DIMATFIT" 3) (cons "DIMBLK" "_ARCHTICK") ) ) (vla-copyfrom obj_dim adoc) (vla-setvariable adoc "DIMBLK" ".") (vla-copyfrom obj_angdim adoc) (princ "\nSelect polylines: ") (while (null (setq pl (ssget '((0 . "LWPOLYLINE")))))) (repeat (setq n (sslength pl)) (setq ent (ssname pl (setq n (1- n))) obj (vlax-ename->vla-object ent) dxf_ent (entget ent) lst_pt (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent)) ) (vla-GetBoundingBox obj 'll 'ur) (setq ll (safearray-value ll) ur (safearray-value ur) dir_pt (mapcar '* (mapcar '+ ll ur) '(0.5 0.5 0.5)) base_pt (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt)) dir_ang (if (< (- (angle base_pt (polar base_pt (+ (angle (car lst_pt) (cadr lst_pt)) (* 0.5 pi)) (getvar "DIMTXT"))) (angle base_pt dir_pt)) pi) (* pi 0.5) (* pi 1.5) ) ) (if (not (zerop (logand 1 (cdr (assoc 70 dxf_ent))))) (setq last_pt (car lst_pt) lst_pt (cons (last lst_pt) lst_pt) pr_pt (last lst_pt)) (setq pr_pt nil) ) (while (cdr lst_pt) (vla-put-activedimstyle adoc obj_dim) (setq nw_obj (vla-addDimAligned space (vlax-3d-point (car lst_pt)) (vlax-3d-point (cadr lst_pt)) (vlax-3d-point (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt))) ) ) (vlax-put nw_obj 'TextPosition (polar (vlax-get nw_obj 'TextPosition) (+ (angle (car lst_pt) (cadr lst_pt)) (+ dir_ang pi))(* 3.25 (getvar "DIMTXT")))) (if pr_pt (progn (vla-put-activedimstyle adoc obj_angdim) (setq nw_obj (vla-AddDimAngular space (vlax-3d-point (car lst_pt)) (vlax-3d-point (cadr lst_pt)) (vlax-3d-point pr_pt) (vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 5.0 (getvar "DIMTXT")))) ) pr_pt (car lst_pt) ) ) (setq pr_pt (car lst_pt)) ) (setq lst_pt (cdr lst_pt)) ) (if (and pr_pt last_pt) (setq nw_obj (vla-AddDimAngular space (vlax-3d-point (car lst_pt)) (vlax-3d-point pr_pt) (vlax-3d-point last_pt) (vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 3.25 (getvar "DIMTXT")))) ) pr_pt (car lst_pt) ) ) ) (princ) ) Â I changed the variables DIMDEC=3, DIMTDEC=3 and DIMLUNIT=2. The variable DIMGAP was fixed at 0.09, I made it change with the height of the text so that the distance is proportionate to the dimension line. There was an error at the end of the program, it warned me of an unknown point and in fact the variable last_pt was nil. Very interesting little program. You don't have time to learn the dimension variables in one version of AutoCAD and Autodesk comes up with new variables, which I obviously don't remember, and as I've already told my buddy Mhupp, I'm lazy... Edited September 29, 2021 by confutatis 1 Quote
zwonko Posted September 29, 2021 Posted September 29, 2021 Really nice code!!!! Changed it to use current dimstyle, not adding new one. (defun c:DimPline2zw ( / adoc space obj_dim obj_angdim height_dim pl ent obj dxf_ent ll ur dir_pt base_pt dir_ang last_pt pr_pt lst_pt nw_obj) (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) space (if (= 1 (getvar "CVPORT")) (vla-get-paperspace adoc) (vla-get-modelspace adoc) ) ) ;;(vla-put-activedimstyle adoc obj_dim) ;;(initget 6) ;;(vla-copyfrom obj_dim adoc) ;;(vla-setvariable adoc "DIMBLK" ".") ;;(vla-copyfrom obj_angdim adoc) (princ "\nSelect polylines: ") (while (null (setq pl (ssget '((0 . "LWPOLYLINE")))))) (repeat (setq n (sslength pl)) (setq ent (ssname pl (setq n (1- n))) obj (vlax-ename->vla-object ent) dxf_ent (entget ent) lst_pt (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent)) ) (vla-GetBoundingBox obj 'll 'ur) (setq ll (safearray-value ll) ur (safearray-value ur) dir_pt (mapcar '* (mapcar '+ ll ur) '(0.5 0.5 0.5)) base_pt (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt)) dir_ang (if (< (- (angle base_pt (polar base_pt (+ (angle (car lst_pt) (cadr lst_pt)) (* 0.5 pi)) (getvar "DIMTXT"))) (angle base_pt dir_pt)) pi) (* pi 0.5) (* pi 1.5) ) ) (if (not (zerop (logand 1 (cdr (assoc 70 dxf_ent))))) (setq last_pt (car lst_pt) lst_pt (cons (last lst_pt) lst_pt) pr_pt (last lst_pt)) (setq pr_pt nil) ) (while (cdr lst_pt) ;;(vla-put-activedimstyle adoc obj_dim) (setq nw_obj (vla-addDimAligned space (vlax-3d-point (car lst_pt)) (vlax-3d-point (cadr lst_pt)) (vlax-3d-point (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt))) ) ) (vlax-put nw_obj 'TextPosition (polar (vlax-get nw_obj 'TextPosition) (+ (angle (car lst_pt) (cadr lst_pt)) (+ dir_ang pi))(* 3.25 (getvar "DIMTXT")))) (if pr_pt (progn ;;(vla-put-activedimstyle adoc obj_angdim) (setq nw_obj (vla-AddDimAngular space (vlax-3d-point (car lst_pt)) (vlax-3d-point (cadr lst_pt)) (vlax-3d-point pr_pt) (vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 95.0 (getvar "DIMTXT")))) ) pr_pt (car lst_pt) ) ) (setq pr_pt (car lst_pt)) ) (setq lst_pt (cdr lst_pt)) ) (if (and pr_pt last_pt) (setq nw_obj (vla-AddDimAngular space (vlax-3d-point (car lst_pt)) (vlax-3d-point pr_pt) (vlax-3d-point last_pt) (vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 95 (getvar "DIMTXT")))) ) pr_pt (car lst_pt) ) ) ) (princ) ) Â But there is small problem with dimstyle override for angular dimensions. Look on sample dwg. Is any way to correct it? Thinking about get back to previous code with chosen styles, and for angulat it should get dimstyle named "currdimstyle+$2" test.dwg Quote
confutatis Posted September 29, 2021 Posted September 29, 2021 In fact you should use two styles, one for linear dimensions and one for angles. If you manage the dimensions with DDIM, you can change the appearance of the corner by restoring the dimension lines, but afterwards it also displays the elements of the linear dimensions. Quote
JudiHughes Posted September 29, 2021 Author Posted September 29, 2021 Thanks All, Both worked fine and once again thanks for all your help. Â Judi Quote
zwonko Posted September 30, 2021 Posted September 30, 2021 So for my purposes the code looks like below: (defun c:rbrdesc ( / adoc space obj_dim obj_dimm obj_angdim obj_angdimm height_dim pl ent obj dxf_ent ll ur dir_pt base_pt dir_ang last_pt pr_pt lst_pt nw_obj) ;;(princ "\nworking: ") (setq obj_dimm (GETVAR "DIMSTYLE")) (setq obj_angdimm (GETVAR "DIMSTYLE")) (setq obj_dimm (strcat obj_dimm)) (setq obj_angdimm (strcat obj_angdimm "$2")) ;;(princ "\nworking1: ") (vl-load-com) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) space (if (= 1 (getvar "CVPORT")) (vla-get-paperspace adoc) (vla-get-modelspace adoc) ) obj_dim (vla-add (vla-get-Dimstyles adoc) obj_dimm) obj_angdim (vla-add (vla-get-Dimstyles adoc) obj_angdimm) ) (vla-put-activedimstyle adoc obj_dim) (initget 6) ;;(princ "\nworking2: ") ;;(vla-copyfrom obj_dim adoc) ;;(vla-setvariable adoc "DIMBLK" ".") ;;(vla-copyfrom obj_angdim adoc) (princ "\nSelect polylines: ") (while (null (setq pl (ssget '((0 . "LWPOLYLINE")))))) (repeat (setq n (sslength pl)) (setq ent (ssname pl (setq n (1- n))) obj (vlax-ename->vla-object ent) dxf_ent (entget ent) lst_pt (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent)) ) (vla-GetBoundingBox obj 'll 'ur) (setq ll (safearray-value ll) ur (safearray-value ur) dir_pt (mapcar '* (mapcar '+ ll ur) '(0.5 0.5 0.5)) base_pt (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt)) dir_ang (if (< (- (angle base_pt (polar base_pt (+ (angle (car lst_pt) (cadr lst_pt)) (* 0.5 pi)) (getvar "DIMTXT"))) (angle base_pt dir_pt)) pi) (* pi 0.5) (* pi 1.5) ) ) (if (not (zerop (logand 1 (cdr (assoc 70 dxf_ent))))) (setq last_pt (car lst_pt) lst_pt (cons (last lst_pt) lst_pt) pr_pt (last lst_pt)) (setq pr_pt nil) ) (while (cdr lst_pt) (vla-put-activedimstyle adoc obj_dim) (setq nw_obj (vla-addDimAligned space (vlax-3d-point (car lst_pt)) (vlax-3d-point (cadr lst_pt)) (vlax-3d-point (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt))) ) ) (vlax-put nw_obj 'TextPosition (polar (vlax-get nw_obj 'TextPosition) (+ (angle (car lst_pt) (cadr lst_pt)) (+ dir_ang pi))(* 3.25 (getvar "DIMTXT")))) ;;(setq obj (vlax-ename->vla-object (entlast))) ;;(wcmatch (strcase (vla-get-objectname obj)) "*DIM*") ;;(setq txt (vla-get-measurement obj)) ;;(if (= txt 100) ;;(vla-delete obj) ;;) (if pr_pt (progn (vla-put-activedimstyle adoc obj_angdim) (setq nw_obj (vla-AddDimAngular space (vlax-3d-point (car lst_pt)) (vlax-3d-point (cadr lst_pt)) (vlax-3d-point pr_pt) (vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 95.0 (getvar "DIMTXT")))) ) pr_pt (car lst_pt) ) (setq obj (vlax-ename->vla-object (entlast))) ;;(wcmatch (strcase (vla-get-objectname obj)) "*DIM*") (setq txt (vla-get-measurement obj)) (if (= txt (/ pi 2)) (vla-delete obj) ) ) (setq pr_pt (car lst_pt)) ) (setq lst_pt (cdr lst_pt)) ) (if (and pr_pt last_pt) (setq nw_obj (vla-AddDimAngular space (vlax-3d-point (car lst_pt)) (vlax-3d-point pr_pt) (vlax-3d-point last_pt) (vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 95 (getvar "DIMTXT")))) ) pr_pt (car lst_pt) ) ) ;;(setvar "DIMSTYLE" "standard") (command "-DIMSTYLE" "restore" obj_dimm) ) (princ) ) Â Â Main changes are: -it is getting current dimstyle -it is working within dimangular with dimstyle overide for angular dimensions -it should delete dimang if it is 90degress -also turn of one code line which was making aligned dimension "not compatibile" with lisp below (getting dimtext up/down) Â (defun c:dimupd ( / sel ) (if (ssget "_:L" '((0 . "DIMENSION"))) (progn (vlax-for obj (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))) (if (= acunder (vla-get-verticaltextposition obj)) (vla-put-verticaltextposition obj acabove) (vla-put-verticaltextposition obj acunder) ) ) (vla-delete sel) ) ) (princ) ) (vl-load-com) (princ) Â Â Quote
