Geoffers
It must be  more than 5 years ago I last dropped into this site. I recognise a few names but the list of all members seems to have disappeared...
Anyway, the question:
I am trying to make 2 macros for the Tools palette to turn layer Vport on and Vport off to avoid having to scroll up and down the layers palette.
Can anyone please advise me why the following, say for 'Vport On' does not work
^C^C layer ON; Vport;;
I am waiting for the "oh yes, of course" moment when some solves it. Thanks in advance.
Link to post
BIGAL
A mistake you need to look at spaces ^C^C layer ON; Vport;;  ps no space after ctrl+c some commands have ^p as well.
Also try -layer, layer will pop dialouge box.
So -layer on "vport" then question ?
Do it all manual write it down each space is a return.
Link to post
Geoffers
Thanks for the info, I will give it a go when I open up ACAD LT later. Appreciated.
Link to post
tombu
I use a modified version of layer-toggle-freeze.lsp by Jimmy Bergmark in a Ribbon Drop-Down Menu for lists of layers to toggle freeze or thaw.
 Example:
^P(or layer-toggle-freeze(load "layer-toggle-freeze.lsp"))(layer-toggle-freeze '("Vport"))
or
^P(or layer-toggle-freeze(load "layer-toggle-freeze.lsp"))(layer-toggle-freeze '("V-NODE" "V-NODE-CNTR" "V-NODE-CURB" "V-NODE-DRVE" "V-NODE-DRIVE" "V-NODE-EOP" "V-NODE-EOR" "V-NODE-EOW" "V-NODE-ESW" "V-NODE-GARB" "V-NODE-GRAV" "V-NODE-LINE" "V-NODE-MRW" "V-NODE-RAIL" "V-NODE-SSWR" "V-NODE-TOB" "V-NODE-TOE" "V-NODE-TOEG" "V-NODE-TOPD" "V-NODE-TOPG" "V-NODE-WATR" "V-NODE-WETL"))
as an example of a large list of Surface point layers I often toggle frozen/thawed.
I use distinctive images like RCDATA_16_VPONE for the Vport layer or TRANSCMD_POINT_OBJECT_16 for the Surface point layers.
Edited by tombu
Link to post
Geoffers
tombu, thanks for the reply.
Unfortunately I am reduced to ACAD LT for Mac (sob, sob) so no lisp available! ( ACAD LT suits me in my retired status for my own new house design work.)
Interesting though.
Link to post
BIGAL
This can be done in Bricscad with a cheap house add on contact me. Its 3d based so elevations are easy.
Edited by BIGAL
Link to post
