Combining two lists by key number
lastknownuser
Need a little help with some list combining. I have two lists:
(1 2 3 4)
( (1 a) (2 b) (2 c) (2 d) (3 e) (4 f) )
And I want to combine them to one list, by key number, like this:
( [1 (1 a)] [2 (2 b) (2 c) (2 d)] [3 (3 e)] [4 (4 f)] )
Link to post
lastknownuser
I came up with something like this quickly, but I can't figure out how to group second list by one key number.
(defun c:test ( / n m len1 len2 list3 list4)
  (setq list1 (list "1" "2" "3"))
	(setq list2 (list '("1" "a") '("2" "b") '("2" "c") '("2" "d") '("3" "e") ))
        (setq n 0)
        (setq len1 (length list1))
        (setq len2 (length list2))
        (while (< n len1)
	    (setq m 0)
	    (while (< m len2)
	    (if (= (nth n list1) (nth 0 (nth m list2)) )
		   (setq list3 (list (nth n list1) (nth m list2)))
		   (setq list4 (cons list3 list4))
);progn
);if
(setq m (+ m 1))
);while
(setq n (+ n 1))
);while
(reverse list4)
);defun
The result is:
(("1" ("1" "a")) ("2" ("2" "b")) ("2" ("2" "c")) ("2" ("2" "d")) ("3" ("3" "e"))
But I need the lists with number 2 all grouped, like this ("2" ("2" "b") ("2" "c") ("2" "d"))
Edited by lastknownuser
Link to post
Lee Mac
Consider the following -
(defun foo ( a b / y )
    (setq a (mapcar 'list a))
    (foreach x (reverse b)
        (if (setq y (assoc (car x) a))
            (setq a (subst (vl-list* (car x) x (cdr y)) y a))
    a
For example:
_$ (foo '("1" "2" "3" "4") '(("1" "a") ("2" "b") ("2" "c") ("2" "d") ("3" "e") ("4" "f")))
(("1" ("1" "a")) ("2" ("2" "b") ("2" "c") ("2" "d")) ("3" ("3" "e")) ("4" ("4" "f")))
I'm unsure how you wish to handle these cases:
_$ (foo '("1" "2" "3" "4" "5") '(("1" "a") ("2" "b") ("2" "c") ("2" "d") ("3" "e") ("4" "f")))
(("1" ("1" "a")) ("2" ("2" "b") ("2" "c") ("2" "d")) ("3" ("3" "e")) ("4" ("4" "f")) ("5"))
_$ (foo '("1" "2" "3" "4") '(("1" "a") ("5" "f")))
(("1" ("1" "a")) ("2") ("3") ("4"))
Edited by Lee Mac
Link to post
ronjonp
Another for fun:
(setq l '(("1" "a") ("2" "b") ("2" "c") ("2" "d") ("3" "e")))
(setq k '("1" "2" "3"))
(mapcar '(lambda (x) (cons x (vl-remove-if-not '(lambda (y) (= x (car y))) l))) k)
Link to post
