Changing Height of 3D solids with AutoLISP
AChartier627
I am creating dynamic 3D blocks using meshes, which I can easily stretch by using a dynamic stretch and changing that attribute thanks to the coding of @Lee Mac (many thanks).
However, I cannot make meshes appear in projected or section views in my layout.
So, I am looking for an alternative.
Is it possible to change the height value of an extruded solid using AutoLISP.
Thanks in advance
Link to post
BIGAL
Depending on what it is your drawing if its basic pline extruded and not a number of solids Unioned then there may be a way, its what I call 2.5D you make a pline and set the property thickness to what you want it will appear hollow but you can use Pface to put a top on it.
The object on right has a pface and I have used HIDE
Edited by BIGAL
Link to post
