emhigginson Posted February 11, 2009 Share Posted February 11, 2009 Hello all, I am making a plan enlargement callout that will have 8 pairs of identical attribute text. Each pair will be turned on or off by a visibility parameter. (4 at the corners with a dogleg leader and 4 at the halfway points on a straight leader) What I want to be able to do is have the sheet and detail attributes be linked so that if I type in a number and page it will be the same in all 8 instances within that particular block in case I need change which one I'm using. Thanks! Quote Link to comment Share on other sites More sharing options...
